Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub ztr 50'' with 22 hp Briggs. PROBLEM: Engine dies with or without deck engaged! I replaced fuel pump, fuel filter, plugs,and cleaned air filter. Could my problem be a (sometimes good / sometimes bad) safety switch? Thanks in advance for any help!!!
  • 496 Answers
Need more info...
When it dies, does it crank back up? if not, at this time, you could check for spark. If none, you might be on track with a fault in a switch.
But if you have spark and it doesn't crank,
check for condesation in the gas (carburator and fuel tank). If any, problem solved... drain and dry carb bowl and gas tank to insure all trace of water is out.
Hope this helps... Good luck!
Posted on Sep 16, 2009
I have a Cub Cadet Model 364 with a 18 H.P Briggs & Stratton motor. It runs fine for about 20 minutes. Than starts hesitating. Like the motor wants to stall out. Help!
Firstly, try to run the engine without cap on the fuel tank. If it stays running well, clean out the ventilation hole in the fuel cap ( or replace the fuel cap ).
Check for dirt in the fuel tank, fuel tank connections, hose, strainer, filter. Clean everything!
Check if you still have sparks when the engine stopped from itself.
Check if you still have compression when engine has stopped from itself ( valve settings too close )
Sep 28, 2016 | Cub Cadet Garden
Wh;y does my cub cadet 1554 tractor mower lose power when engaged?
  • Does deck turn freely? Check and be sure mowing deck is not jammed or bad bearing etc. If nothing is wrong with deck, then check fuel filter, air cleaner element, dirty fuel system, bad gas, water in fuel, restricted fuel flow. Lack of fuel will cause engine to have lack power.
Aug 15, 2014 | Cub Cadet Garden
Why does engine speed decrease when blades are engaged?
need to clean grass from under mower change plug and air filter for better perfomance
Jun 15, 2012 | Garden
Low power when under load lt1024 cub cadet 24 hp els 725 ohv
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb also check muffler for carbon build up clogged muffler means no power
May 16, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Engine dies when when you engage mower or gear
First I would check that the air filter is not stopped up. Second I would clean the carb very well as I believe the high speed circuit in your carb is obstructed. The mower will idle on the low speed circuit but I think it is getting insufficient fuel when you load it. This is where the high speed circuit comes in to allow the additional fuel for higher demand operations like moving in gear and especially the blades.
I hope that this helps.
Jul 15, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a sears lawn tractor with a 25 hp ohv briggs and stratton engine. The problem is that it runs very rough, black smoke and has no power when the deck is engaged. I have replaced the air filter,...
So have you actually checked spark to both plugs? If so then inspect valves to be sure valves are operating. Sounds like running on one cylinder. A quick check would be to unplug one spark plug at a time. You may find if you remove the dead plugh wire, there is no change. If you unplug the running cylinder it probably won't start. Sometimes the compression release mechanisms can come apart or come loose. Download your manual for you engine model at www.briggsandstratton.com
Aug 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 15.5 hp ohv briggs n stratton on a craftsman riding mower when I engage the blades or let out on the clutch the engine dies out tried disconnecting seat switch ,replaced spark plug and fuel...
There is a switch underneath the seat that will shut the engine down if the mower is engaged and you are not on the seat...that switch is bad and it thinks you are not on the seat so it shuts you down...
heatman101
Aug 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
292 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
