Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Two of the elements on my stove get red hot (the little ones ) and the big ones don't get as hot what is wrong
    President:
  • Frigidaire Master
  • 1,922 Answers
The larger elements use 240 volts and your losing 1 leg of the 240volts and only getting 120volts to these elements
Posted on Sep 13, 2009
Neff oven element glows white
It sounds like the wrong replacement element for the power it is getting. If you are using a 220Volt stove, the element MUST be for that voltage and NOT for 110 Volts.
Jan 23, 2013 | Neff U1721 Double circotherm Electric Oven
The grill gets hot but doesn't brown the food?
Normally, if a grill element fails, it just stops working. So if they are working then on full power, both elements should get red hot! If this is the case, all I suggest is that you try experimenting with different heights with the grill tray. And by the way, don't shut the door when you are grilling as this shuts the grill off!
Oct 28, 2011 | Stoves 720EF Electric Double Oven
My sister's oven element burned out. Never having replaced one before, I asked a friend how to get it out & he told me. I asked about turning power off & he said as long as the oven is off no need....
First, you should always turn the power off to replace the element. One side of the element always has 120 VAC applied and it turns the oven on by applying 120VAC to the other side giving 240 across the element. Most ovens have L1 branching out to both the bake, and broil elements, and it also branches out to the control board and all of the switches that run your top elements. If you don't have an element in the bottom, its likely that L1 is grounded out and is tripping the breaker as soon as it's turned on. So if you install the new element it should fix your problem, however if it doesn't you might have burned up the L1 wire somewhere and will just have to trace it back.
Jan 30, 2011 | Ovens
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
Apr 17, 2010 | Ovens
Stove is not getting hot or elements
sounds like you've lost one phase of your 240 volt power
Sep 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
Aug 24, 2009 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
103 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
