Question about Craftsman Garden
Craftsman 2550 PSI pressure washer has no pressure
Craftsman 2550 PSI 2.3 gallon pressure washer has no pressure. Worked a while back fine. I hadn't used it in a while and no pressure builds up. I tried backwashing the hose, the end nozzles, everything I could think of. No luck.
  • 1 more comment
  • bhchandler20 Sep 12, 2009
    Any chance you can give me a little more info on how to do that? Do I remove the pump completely from underneath the motor? What exactly is the coupler that I'm looking for? You say to see if the pump is turning. Does that mean it has to be powered on while I'm checking this meaning I don't take anything apart?
  • bhchandler20 Sep 13, 2009
    I took the pump off and both the motor and the part that the motor attaches to in the pump spin. I can see absolutely no leaks. I am so lost as to why it's not building pressure.
    I don't know how to determine that. The "male" part from the motor that inserts down into the pump part is definitely turning when the motor is running and since the part from the pump does turn by hand, I can't see how the motor wouldn't be turning that part when they are connected. How can I determine that?
    President:
  • 1,167 Answers
Is there are in the sytem is there water leaking on the inside strip the pump off and check the blades havent corroded and broken off or the shaft has worn so the motor is just spinning on its own check the seals havent gone
Posted on Sep 13, 2009
    President:
  • 1,714 Answers
Check the pump/ motor coupling to verify pump is turning.
Posted on Sep 12, 2009
  • Craig Butler
    Craig Butler Sep 13, 2009
    With it off, take the cover off the pump and see if you can turn the pump by hace, or the motor. If it's seized or if the coupling is sheared. If the pump is working and driven by the motor, you would have pressure. It isn't leaking when it's on is it? Spraying all your pressure from a leak?
  • Craig Butler
    Ok, you say the motor and the coupling spin, but is the pump spinning when motor is running?
After the winter my motor runs fine but no water pressure
Did you drain the pump in the fall? Cracked housing or blown gasket.
Apr 22, 2014 | Garden
Troy bilt 2550 psi pressure washer My friend gave
Try this link. I think you'll find what you're looking for.
http://www.troybilt-gen-pw.com/owners_manual/
Nov 04, 2013 | Garden
No high pressure water coming from soap inlet
have one of these same problem last month had to pull the pump off the bottom and free up the pump then worked
Apr 15, 2013 | Craftsman 2550 MAX PSI Briggs & Stratton...
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
Cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Jun 23, 2009 | Karcher 2500 PSI Pressure Washer
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
No water pressure
There is a injector valve in the water pump that is sticking. Remove this valve, grease the top o-ring and reinstall. Problem solved. Use pump guard in the future to prevent this problem from reoccuring.
Mar 22, 2009 | Karcher 2500 PSI Pressure Washer
Oil stick is stuck
Have you ever checked it before? Do you know if it's a screw on cap? It could be that the cap is slotted, and is only supposed to turn a 1/4 turn. Try not to force it, and use a light touch.
Hope this helps!
C
Sep 27, 2008 | Craftsman 10.5 Hp 33" Commercial Cutting...
Garden Logo
483 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
