Question about Senco FP18 FinishPro 18 - Gauge Brad Nailer, 5/8" - 2"
My Senco PC1010 Air Compressor just quit and won't power on, any idea what could be wrong?
    President:
  • 1,167 Answers
On a compressor by the motor or on the pressure switch there will be a overload switch which may have tripped out push this back in and try it it is a black button pocking out the motor or switch buddy get back to me if this doesnt work budd
Posted on Sep 13, 2009
How to clean the air filter on my senco PC1010
just unscrew or lift off the cap.
dust out and replace
Sep 27, 2016 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
Envoy air ride compressor
The load leveler sensor operates the compressor. It most likely is malfunctioning. It is located on the rear drivers side lower control arm.
May 05, 2014 | 2002 GMC Envoy
Senco pro frame 601 just blows air when trigger is pulled
Senco nailers are mostly not lubricated but moisture and dirt do they have the neck compressor not tapped in time and then inside the top cover of this tools can have that or the parts are hanging can not move freely and clean, solvent them out and grease it with silicon OKS1110 Kluber Silubrin or Dow Corning DC4 in most cases the models of Senco are oilless IF the seal of the piston is made out of kevlar instead of a plain o-ring .
Jan 20, 2014 | Senco 1G0003R FactoryReconditioned...
Senco air compressor pumps up..when it reaches full pressure it shuts off and then something under the electronic box opens and discharges all of the air.
That is the safety relief valve which means it has gone bad or you need to turn back the high pressure setting about 5 t0 10 psi. When this happens again there should be a small pin in the middle of it that has a metal ring through it. When it goes off push on that pin and if the air coming out stops or shuts off then you need to turn back the psi if not the valve needs replaced.
May 09, 2011 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
Where can I buy a new pressure regulator for my Senco PC1010 Compressor?
Normally these pressure switches are universal... Granger's is a good place to get parts like this.
Oct 29, 2010 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
Wont air up tank pressure. motor runs & tank pressures to about 25lbs
below the pressure switch is a unloader valve which has a tendency to leak, undo that line and block it off, if this works you probabaly can leave it blocked off.
Dec 02, 2009 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
The compressor runs (rather noisy) but the pressure increases very slowly and not very high
Please do not take offense to anything I say but your compressor because it has nothing to do with you. It's a personal grudge against that particular air compressor and the Air Compressor **** that designed and built it. It is a piece of junk, and that's the nicest thing I can say about it.. The model you have was built for one thing and one thing only. It was to get an air compressor into the hands of customers that never really needed an air compressor for anything more then inflating a tire or a basketball. My friend's mother bought him one because, as she put it "it was cute". In all seriousness it is a throw away air compressor. I have seen several go bad with less then 30 hours time on the pump and motor. If it is bad and from your description it sounds like it, there is nothing you can do about it. Impossible to get parts for unless they come from another one of the same type. I'm sorry that I can't be more helpful. What I can say is you are better off to replace it. There are plenty of similarly sized and priced compressors that are far superior to the 3gal. 11/2 hp craftsman. The Senco PC1010 is a great compressor for it's size and specs. Good luck
Nov 09, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Senco finishpro ,the casting at the end of the handle where the air nipple srews in, is broken. where can I get a new one? and where on the tool can I find the model number?
Go to Senco.com and type in your model number. It should be on a plate somewhere on the tool, if not there is a toll free number for their tech support that can help you with this problem.
Sep 18, 2009 | Senco PC0974 Finish Pro 10 23 Gauge Pinner...
Senco FP18 FinishPro 18 - Gauge Brad Nailer, 5/8" - 2" Logo
203 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
