Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
The hard drive makes a loud noise and isn't detected by my computer
Check the power supply first mine sounded like a coffee grinder and it was still the supply, I have 2 of these here and swapped in the other supply, solence and normal operation.
Posted on Feb 25, 2010
  • 3,153 Answers
Hard drives themselves do not tend to make loud noises.
If it clicking ticking or similar then External hard drives are quite prone to this but it can also affect internal too to a lesser degree
The clicking you hear is referred to as the "Click of Death" as far as hard drives are concerned. It may sound like a regular click or ping.
And I am afraid it is as it says.
It was probably knocked, dropped, or maybe just mis-handled.
These are hard drives and not flash drives.
As such should be treated with care
If it is truly dead and you MUST have the information from it then the only real alternative is to send it to a data recovery expert.
These services are NOT cheap
It is possible that on external hard drives you may just be using the wrong USB lead try a shorter one preferably the one that came with it.
Another trick is to remove the drive from its enclosure and where a SUITABLE PC is available you can often connect it directly inside the PC.
If you are extremely lucky you might be able to salvage information but this is not always the case.
If it is the drive and it was in an enclosure you can always put a new one in there.
DO NOT PUT IT IN A FREEZER OF SLAP IT !
The freezer advice is meant for very old types of hard drives that used to get extremely hot and in very rare cases this extremely old trick was used just to get information from those old drives.
Hitting or slapping the drive causes shock on a hard drive that can kill it stone dead.
Posted on Sep 13, 2009
  • 125 Answers
If your hard drive makes a rattling or scratching or grinding noise, its not likely to work again. I have searched Google for this problem when it happened to mine and they recommended trying to put it in a freezer to chill it and because of metal shrinkage, it could allow the bearing to turn again more freely. Of course this is not a fix, but a possible solution to get it running long enough to get some data off of it before it heats up again. I hope this helps. There's not much else you can do other than send it to www.drivesavers.com who are a data recovery service that is highly rated.
Posted on Sep 12, 2009
    Scholar:
  • 77 Answers
Sounds like the Hard Disk inside the Lacie has failed. Drives typically have an average 5 year lifespan, some last longer and some can fail much sooner. Unfortunately, you rarely have any warning.
Some things to try before we assume this is true -
1. Bad Cable - Well it is probably unlikely, but I would first try another USB cable just to make sure the cable is not damaged.
2. Power Supply - Try another power supply if you have or can borrow one.
Also powercycling both the drive and laptop could help - but i truly believe the drive went bad.
    Brigadier General:
  • 4,044 Answers
Replace the hard drive. You have bad sectors in the MBR section or the head readers have become faulty.
3 Suggested Answers
  • 8 Answers
SOURCE: my external hd makes a constant, loud noise
Back up your files and buy a replacement drive the grinding noise is the hard drive experiencing mechanical failure and may stop working soon.
Posted on Oct 08, 2009
anjana03
  • 361 Answers
SOURCE: My computer is not detecting my LaCie Hard Drive
there is a usb port inside hd .box /many time it is damage and also usb cablle damage . so once time change this thing one by one to check. there is a rare chance to damage hdd. we have facinge many time same problem. this hdd and laptop hdd are same. only potr is diffrent, (nepal)
Posted on Oct 09, 2009
My extenal Hard disk seagate free agent 500 gb is not detected by my laptop
try all usb inputs. if it still isn't try another computer. It should be found. Make sure it is plugged in just right or wiggle to see if it finds it. if not then maybe the hard drive is 3.0 usb and the computer is 2.0 just some thoughts
Sep 15, 2012 | Seagate 500GB FreeAgent GoFlex Hard Drive
My Western Digital Caviar WD1600BB 160 GB hard drive in my dvd recorder is making a clicking sound, how do I test to see if it is the heads that are faulty or the circuit board?
Welcome to Fixya. If you are hearing a loud ticking or high pitch noise on the hard drive it means that the hard drive will be defective anytime soon. If you can take out the hard drive and backup the files on you computer and replace the hard drive on the computer. Loud noise can be caused by a bad spindle or the hard drive or the hard drive is frying inside the dvd recorder.
If you have questions please let me know. Thanks
Oct 10, 2011 | Western Digital Caviar WD1600BB 160 GB...
My hitachi hard drive Hitachi HDT721064SLA380 isn't detected by computer and i can here a sound "tic tic" in the HDD ,Thanks .
Hi Welcome to Fixya!
Your hdd is making that sound mainly because it could already be damaged inside. That is also the reason why it is not being detected by the computer.
Same thing happened to me with my 120gb Seagate Barracuda.
Consider in replacing the hard drive on your computer.
Hope this could help!
Have a great day!
Jun 30, 2011 | Hitachi Deskstar 7K1000.B HDT721064SLA380...
It's making an extremely loud noise it may be the fan but i'm not sure :)
Good day. What you can do too resolve this issue is to clean your fan from dust.. Usually the fan sucks in dirt while keeping your system cool, overtime this dust clogs your fan causing a loud noise. You can also check your hard drive because defective or hard drives that have problem causes scratching noise as well. Hope this information help you a bit. Have a great day.
May 29, 2011 | Dell XPS 200 PC Desktop
My son threw the hard disk and its not being detected anymore. The hard disk makes a screeching noise when plugged in. Looks like the disk is done. Any solution ???
Hard disks DO NOT like hard knocks, this hard disk is broken, especially when they make loud noises.
It can't be fixed, by us mortals. Cheaper to get a new one.
Apr 20, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Have Fujitsu MVH 2040 BH hard drive making a steady, low level noise similar to static. Its not that loud but it was not there before. It also occasionally makes a fairly loud single chirp noise that...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 10, 2011 | Fujitsu MHV2040BH 40 GB SATA Hard Drive
My external hd makes a constant, loud noise
Oct 08, 2009 | LaCie Computers & Internet
Same thing
if its making a loud clicking noise i would guess that the hard drive got jolted hard while shipping if possible send it back and get another one or if you have another hard drive put it in install windows and discard other drive very rare for them to get damaged during shipping(maybe you can get them to just send hd(hard drive)and drivers instead of whole computer!!!
Sep 06, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Computer will not boot
Does your pc make a different noise than usual when you turn it on? If it sounds like clicking (loud) then your hard drive has crashed. You will need to replace it.
May 28, 2009 | Gateway Profile 4 All In One (MPN...
Maxtor hard drive
if it stops and after some time it stop making noise then it means its having problem with the magnetic plates so i suggest you to change the drive.
maxtor drives are very sensitive to shocks may be it get a shock.
Jan 16, 2008 | Maxtor Hard Drive
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
807 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
