Question about Bose Companion 3 Computer Speakers
No audio The speaker system was powered up for approximately 2 weeks uninterupted and unattended. They were not being used, just powered up. When I attempted to play music through them, they would not play. I do here slight crackling in the speakers when I unplug and plug them in. This happened once before and powering them down and back up resolved the problem. Now nothing. Any ideas? Thanks in advance. Bob
I had a set of companion3 speakers with no shound and it turned out to be the volume control module that sits on the desk and you rotate it to turn the volume up or down, and touch it to mute it. Bose replaced it for free.
Posted on Jan 19, 2008
    Problem Solver:
  • 9 Answers
The internal power supply of the speaker system was busted.
Posted on Dec 11, 2007
Will i be able to swap the original speakers of the J520 with a pair of Sony SS-B1000, without causing damage to the new speakers? the Sony SS-B1000 has an Impedance of 8 ohms, and peak power of 120 watts.
Hi, As long as you like the way the speakers sound there is really no reason you cant use whatever speakers you want. To find out the approximate wattage of the stereo you are using look on the rear of the unit and you will find a tag that has " SPECIFICATIONS " on it. There you will see perhaps the a.m. and f.m. frequencies it's capable of receiving also there should be numbers saying something like" 100-240vac or 100-240v~ 50-60hz 1.2amp or 120watts.( if power is listed in amps only-1 amp's equivalent to about a hundred watts)Dividing the wattage by 3 will give you an approximate power out put. Example if your stereo draws 120 watts worth of 110 from the wall it will put out approximately 40 watts to each speaker. Changing from OEM speakers is all right as long as you don't try to hook up some 150 watt peak speaker to a stereo capable of just, say, 10 watts per channel. Doing this will eventually cause damage to the amplifier, not to mention causing about 30 percent total harmonic distortion-which take my word for you will know if you ever hear it! So long story short-use what you wish, just be careful not to overload the receiver-if the speakers are a bit to powerful for receiver you can lessen distortion by turning down the " BASS" as that takes the most power in a speaker. Thanks for choosing FixYa, I hope this helped-good luck, Prodzilla
Apr 15, 2011 | Audiophase J520 CD Shelf System
It keeps shutting of and the power light just flashes if there is too much bass? what do i do? the volume is low to begin with
Hello, the protect circuit is likely detecting a damaged speaker or speaker wire.Check the unit with one speaker at a time connected, or if you have an ohmmeter measure each speaker they should read approximately 8 ohms.When you connect a speaker thats bad the unit is designed to shut down and flash protect.
Jan 14, 2011 | Sony MHC-GX450 CD Shelf System
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
My amp keeps goin into protection
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your amp is probably OK. The volume is either set to high or the speaker load is to low of an impedance. Remember 2, 8 ohm speakers connected is the same as 1, 4 ohm speaker. Another possibility is that you do not have enough battery power coming to the amp itself. A simple rule I use is take the watts and divide by ten, that will give you an approximation of the amps needed on a 12 volt system. This takes into account some of the losses in the amp, but it is only an approximation. For example 300 watts RMS is 30 amps, which will require a number 8 wire to keep the losses at a minimum. You can check wire drops on the web.
Good Luck,
Gilshultz
Nov 29, 2009 | Kicker ZX1500.1 Car Audio Amplifier
My amp keeps going in and out of protect mode every few seconds it cuts off and then it will cut back on and so forth
Good Luck,
Gilshultz
Nov 29, 2009 | Infinity 475A Car Audio Amplifier
Need replacement supply
go to a ipod retail store like target or walmart
Jul 22, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Wire color codes for '95 Ford stereo
i will post 96 Taurus. Not sure if the same as 95. you did not say which radio you have, base or premium.
please rate as fixya if this is what you need
Base Audio System With/Without Cassette Player
Pin Number Circuit Circuit Function 1 729 (R/W) Battery Feed 2 57 (BK) Power Ground 3 434 (LB/BK) Pulse Width Modulated Illumination Signal (Analog) from Headlamp Switch 4 1002 (BK/PK) IGN/RUN/ACC 5 640 (R/Y) IGN/RUN/START 6 694 (BK/LG) Logic Ground 7 — Not Used 8 — Not Used
Pin Number Circuit Circuit Function 1 593 (DB/W) Tape Audio RH + 2 594 (GY) Tape Audio RH - 3 57 (BK) Ground 4 833 (T) Audio Communications Protocol B 5 1068 (LG/BK) Audio system ON 6 723 (GY/R) Phone Wake Up 7 — Not Used 8 59 (DG/P) Rear Defrost 9 503 (BR/LG) Tape Audio LH + 10 504 (W/PK) Tape Audio LH - 11 — Not Used 12 832 (LB/PK) Audio Communications Protocol A 13 — Not Used 14 — Not Used 15 1010 (DB/O) Heated Back Window 16 — Not Used
Pin Number Circuit Circuit Function 1 803 (BK/PK) RH Rear Speaker (-) 2 802 (O/R) RH Rear Speaker (+) 3 811 (DG/O) RH Front Speaker (-) 4 805 (W/LG) RH Front Speaker (+) 5 801 (T/Y) LH Rear Speaker (-) 6 800 (GY/LB) LH Rear Speaker (+) 7 813 (LB/W) LH Front Speaker (-) 8 804 (O/LG) LH Front Speaker (+) 9 — Not Used 10 747 (R/PK) Power Antenna (Up Signal) 11 — Not Used 12 694 (BK/LG) Ground 13 694 (BK/LG) Ground 14 720 (R/Y) B+ Supply
Mar 06, 2009 | 1995 Ford Taurus
My NAD T763 turns on but no sound comes out of any speakers
HI,
I had the same problem and AH reset did not work. IS there anything else i can do?
Thanks
Adrian
Dec 02, 2008 | NAD T763 Receiver
Speaker Test
Micro-processor malfunction. Take to pro/tech
Feb 23, 2008 | RCA RT2360 System
My speakers on my Dell computer quit working.
1) check audio driver is installed in system or not it may have some one remove audio driver.
2)If driver installed check volume is not mute.
3)If all thing is ok check speaker in another system by connecting it.
4) If spk is working in another system. it means sound card of that system is faulty.
Dec 01, 2007 | Audio Players & Recorders
Bose Companion 3 Computer Speakers Logo
263 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
