Question about Canon imageCLASS D760 All-In-One Laser Printer
Torn gray and brown colored plastic came out of the printer and gives dirty print-outs
  • Canon Master
  • 1,684 Answers
The gray/brown colored plastic is actually the teflon sleeve from the fuser unit in the printer. The fuser is the part that heats up and melts the toner onto the paper. Your fuser sleeve has torn and is being ripped every time you try to print and pieces are coming out causing the bad print. You will need to replace the fuser, the part number is FG6-7947-150 you can order one from several places on the internet.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 13, 2009
Printing from coreldraw 5 to zebra p330i
Sounds as though your printer is dirty, there are unfortunately no different color matchin schemes for this particular printer. The printer operates on an RGB interface, even though it prints using YMC. As far as the speckled look, this typically is due to dust during printing.
Aug 08, 2012 | Zebra P330i Thermal Card Printer
I have a Canon iR1024A that is leaving black streaks down side of paper... I have changed the toner.. cleaned out where the toner goes... and changed the drum... nothing changed.. can you help me
If you have changed the drum then probably your fixing film was torn. Check if the black streaks on paper is erasable (not fixed on the paper). Check also for signs of film (gray on one side and brown on the other very thin plastic-like material) falling out from your fixing assembly (if you open the left side cover with caution sign the hot portion area).
Sep 22, 2010 | Canon ImageRUNNER 1670F Copier
Phantom printing
Most likely the fuser mylar has been torn or is very dirty on the right side. Take the fuser out and visibly inspect for damage. If it is damaged, replace.
Apr 22, 2010 | HP Color LaserJet 2600n Printer
Hp 4050 does not print gray
Please try to edit the setting of your printer particularly the printing level of your printer such as the ink it consumes and the color of the ink you are going to used. So if you want to have a good quality result then please select the best quality printing it can give of your printer by editing the printer setting.
Thanks
Aug 18, 2009 | Office Equipment & Supplies
When printing colour, black appears green
A worn out printhead can allow inks to contaminate each other, after cleaning you need to check your cartridges, if yellow is a brown color, you are getting contamination and need to replace the printhead. Black is hard to tell but when cyan gets too dark it's contaminated as well.
Aug 12, 2009 | Canon BubbleJet i560 InkJet Printer
I have HP4500 printer that printer printing gray/brown type back ground with the print text. same back ground color found when i see the imaging drum and transfer belt.
This is usually a sign of the photoconductor in the drum unit (C4195A) degraded by exposure to light. It will show toned background as you describe after as little as 20 seconds in sunlight, or 3 to 5 minutes in indoor light. The drum kit should always be protected from light by its heavy black plastic bag, or kept inside the top drawer of the printer (keep closed).
Apr 10, 2009 | HP Color LaserJet 4500 Printer
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
HP 1300 makes noise and wrinkles paper
open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Dec 18, 2008 | HP LaserJet 1300 Printer
Shades of gray printing as brown
does the black do a complete nozzle test print.if not clean several times and try nozzle test again
Dec 26, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon imageCLASS D760 All-In-One Laser Printer Logo
299 people viewed this question
old marine
old marine
