My LT04WT monitor started taking a few minutes to turn on and today just quit altogether. Any ideas?
  • 1,684 Answers
This usually indicates a dead power supply. A common problem on LCD monitors after 2-3 years or so. The heat build up in the case causes parts in the power supply called capacitors to bulge and pop, this causes the power supply to not start up right or short out. If you can solder you should be able to do the repair yourself. Go to our web site at:
www.ccl-la.com/badcaps.htm now take the back off of your monitor and replace all of the capacitors that look like the pictures and you should be back going. Be sure to replace the bad caps with high temp caps (105c) not ones from Radio Shack because they will pop again in a month or two and you will have to do it again. We carry the replacement caps or you can order them from several places on the internet. When you pull the bad caps off the board the values you need will be marked on the side of the bad ones. You will need to be sure to reinsert the new caps with the polarity stripe going the same way as the old one comes out. If you have any questions just ask, contact info is on our site. If you don't want to do the repair yourself we offer a repair service for $35 + return shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 12, 2009
Runs at different speeds and quits
Try changen battery. Might be a short.Was it left in the rain (noy good)
Aug 12, 2012 | Worx GT WG150 10 in. 18 Volt Cordless...
The monitor take a few minutes to start up, or the
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 14, 2010 | Xerox XL-775D (Black) 17" LCD Monitor
Monitor starts, about three minutes no picture but
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Proview PL926WBi 19" LCD Monitor
My son moved the monitor from one pc tp another and it worked great for a few days. Today he turns it on and the screen is black and blinks every couple of seconds. I have restarted, unplugged and checked...
Guess to narrow it down, can he put the monitor on another computer to see if it still works? Also putting different monitor on the current computer might give you a few more ideas. At least then you will know have a better idea of where the problem lies. Hard to diagnose this stuff unless you are the one sitting in front of it.
Hope this starts you in some direction.
Dec 09, 2009 | Samsung SyncMaster 205BW LCD Monitor
Bike quit while riding- dead battery
Yeah, and in the rain too.
I think you should take your battery to AutoZone and have it checked.
(No I don't work for them)
Jun 11, 2009 | 1996 Suzuki LS 650 Savage
Acer AL1917 Monitor does not start up immediately.
You'll need to have your power board -inverter redone.
The capacitors are starting to fail and that eventually will stop it all together.
I repair many monitors through ebay with these types of problems.
If you take it apart and send me a picture, I can usually see the problem areas.
ebays
bammbammfran
Nov 05, 2008 | Acer AL1917W LCD Monitor
MacBook Desktop Lost My Desktop Folders
If the colour circle shows... find a tiny bit of wallpaper showing through the back, then click. Then, you should see it labled finder instead of preview. Next, click on the blue apple. If it doesn't happen immediatly, a dropdown bar will show in a couple minutes. In the dropout bar, click Force Quit. It usually takes 2 minutes for the Force Quit window to show up. It'll ask you what you want to force quit,  Look at the choices and force quit all of the ones that say: NOT RESPONDING. Then the computer will clear up for a while, in wich you can probably preview your pictures.
Aug 12, 2008 | Apple Power Mac G4 Dual Mac Desktop
Acer Monitor
You're going to have to provide more info than that.
What were you doing when it happened? What are you typically doing when it happens? Have you checked your cables? Power connection?
As it stands, your inquiry will not receive much of a useful solution for you unless you let us know these things.
And don't rate me poorly for letting you know this. I'm here to help you. You have to HELP US help you.
Cyryl
Dec 10, 2007 | Acer AL1916B 19" LCD Monitor
Monitor Settings Adjust Itself
try connecting some other monitor to the system, if u do not face the issue, then issue is with the monitor, some hardware fault.
Feb 14, 2007 | AOC LM-727 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
