Question about Lexmark X4270 All-In-One InkJet Printer
1200 error just stopped receiving faxs, cartridge will not come to center, how do I fix
  • Anonymous Feb 25, 2008
    rec'vd error 1200 tried turning power off, checking for jams and unplugged from outlet. Turned power off open the printer to see if the cartridge is in correct but cannot manually get the cartridge to move to the center
  • 3 Answers
Tried what blkghost suggested above but had to tweak his advice slightly.
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
YAY problem fixed.
Posted on Mar 20, 2008
Machine shows error #1200
Posted on Feb 13, 2008
THE UNIT SHOWS ERROR CODE 1200
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
You can check this article on how to solve that problem: http://bit.ly/XypLZK
Nov 11, 2012 | Lexmark F4270 Plain Paper Inkjet Fax
We are not able to send faxes,the error message is 1200. The reference number for the fax is x4270.
The 1200 error indicates the cartridge carrier has stalled. It could be caused by a cartridge that's not properly seated or the encoder strip (transparent strip behind the cartridge carrier) is out of place. Refer to this article from the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One to help you identify and resolve the problem.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Nov 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
My fax is getting cartridge error message when
replace your cartridges with new ones or refill old cartridges if you have any
check here how
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Feb 23, 2010 | HP Officejet 5610 All-In-One InkJet...
Error #1200----help cannot receive Fax but can send them
Hi There
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Feb 01, 2010 | Lexmark X4270 All-In-One InkJet Printer
X4270 error 1200
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.By trying physically pulling the carousel to the middle (NOT BY THE RIBBON CABLE) ,if you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.Your problem is fixed.
Aug 27, 2009 | Lexmark X4250 All-In-One InkJet Printer
I have an error #1200 on my fax machine it won't clear
methylated spirits on the cloth , turn machine off, and open the cover as you would do it when replacing cartridge.
make sure machine is turned off so cartridge will not move to center.
clean the chrome metal bar inside machine with the methylated spirits - move the cartridge to the other side of printer manually. and clean the same bar that the cartridge was sitting on.
this should fix the problem.
Dec 09, 2008 | Lexmark X4250 All-In-One InkJet Printer
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
ERROR 1200
The error 1200 refers to a problem with one or both of your cartridges, and as the printer uses these cartridges to print, it will not be able to print any recieved faxes. To avoid lost data, it blocks all fax usage as a result of recieving this message.
Nov 14, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark 4200 Series printer/fax
the printer wont print it reads error #1200
Nov 08, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
230 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
