Question about HP OfficeJet 6210 All-In-One InkJet Printer
I burnt out the ac power adapter. what will it cost to replace
  • 125 Answers
The A/C power adapters cost about $39 from HP. You can order them from their website at www.hp.com. Since you have the old one, check to get all of the numbers off of it, like the volts and watts, etc so you can compare it to the new one and also to any universal adapters you might find in the computer store.
Posted on Sep 12, 2009
Need new charger
Norelco g370 charger power cord
Norelco 4203-035-78420
ac adapter charging cord for all in 1 grooming system norelco g370 power cord replacement parts.
Jul 15, 2015 | Norelco Philips G370 All-in-1 Grooming...
Behringer dsp2024p power adapter burnt...i need the details of the power adapter
It uses a regular AC power cord like on a PC.Here is a link to the manual and on page 10 show a power cord socket of 120v Ac just like on an amp or PC.
http://www.behringer.com/assets/DSP2024P_P0147_M_EN.pdf
Mar 11, 2013 | Music
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Power supply blown
You can check your AC adapter by voltmetter in Dc mode, one probe touches inside the plug, other probe touches outside, it should have dc reading if the ac adapter is working.
Your plug is slightly burnt, indicating that the DC jack is broken or loose.
Most DC jack can be replaced if you know how to solder, it costs only under $5.
http://cgi.ebay.com/DC-Power-Jack-Fu...3286.m20.l1116
I believe your DC jack needed to replace and a repair guy might charge you over $150 to replace a $3 part. You should do it yourself if you have a skill to take a laptop apart.
Car Tuning
May 24, 2012 | Computers & Internet
Well the ac adapter still works and the mic does too but i accedently put the wrong ac adapter to the system that had a higher voltage and i think i blew it out also it stinks like burn plastic were their...
Hi
Electronic equipments dont work with ac supplies. That the fact is they need d.c. and in your case a.c. power goes through rectification and regulation in which case by feeding over voltage into your system you have probably damaged rectifier diodes and the regulator and these items are very cheap.N.B. if you are going to do the repair yourself check for burnt and melted copper tracks.
Jun 30, 2011 | Magic (ED8000) Professional Microphone
Not charging
1.Check the power outlet if it's working.
2.Try to also change the power cord with good one. If it works then the problem is the power cord.
3.Try to use a good know ac adapter to check if the only problem is the ac adapter. If it works then the problem is the ac adapter. If your still in warranty, you can go to this website to get a replacement ac adapter acclaim.toshiba.com or go to toshibadirect.com to order replacement for non-warranty.
4.If could borrow a battery that has same specs and size of your battery , you may put that on your laptop and try if the laptop will power ON. If the laptop won't turn ON, meaning there is a system board problem, if it turns ON the only problem is the ac adapter.
If your still under warranty, you may contact Toshiba, you may send it at no cost.
Mar 16, 2011 | Toshiba Computers & Internet
Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Feb 11, 2009 | Bose Companion 2 Computer Speakers
Car power adapter for portron pdv768
I went to Wal-Mart and purchased a Phillips Power Inverter that provides AC power from any car outlet. Just plug the AC power plug into it and then plug into the lighter plug socket. It solved my problem....It costs $19.99. Hope this helps!
Jun 21, 2008 | Protron PDV-768 Portable DVD Player
HP OfficeJet 6210 All-In-One InkJet Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
