Question about LG enV VX9900 Cellular Phone
My phone just turned off on me and won't turn back on
I mess up the charger port to the point where my phone won't even recognize it unless it's in certain positions. i had it on the charger charging, then it just shut off. and now i can't get it to turn on. i've taken the battery out. nothing seems to be working.
  • alimasood Dec 15, 2007
    where is the turn on button??
  • zacro Dec 25, 2007
    i was on the internet on my enV getting ready to buy a ringtone and then it just shut down and wont turn back on. what can i do to fix this problem. when i push the power button it turns on but it stays on the verizon wireless sign when ur first turn on the phone.
    Problem Solver:
  • 7 Answers
The red "Pwr End" button both inside and outside is how you turn it on or off.
Sounds like you need a trip to the Verizon store or call Verizon
Posted on Dec 19, 2007
My HP Mini 210 1081NR Won't Turn On?
you have a motherboard problem.
Jul 20, 2012 | Computers & Internet
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
Plug-in point of the adapter needs replacement.
Yes, you can probably get the replacement "DC port" on ebay for about $5.00. just search the term dc port and the model of your laptop.
Dell, like most manufacturers, just want to see you a very expensive part, or a replacement notebook, but I have fixed lots of notebooks.
It could be worth checking the port with another identical charger first though, just to make sure it is indeed the port, and not the charger tip.
Fairly straightforward work for a technician... probably cost 1.5 to two hours labour...
I don't advise doing it yourself unless you are experienced in soldering, especially dell dc ports, as the are 3 pin instead of two... 1x battery sense pin.
Hope this info helps.
May 21, 2012 | Dell Inspiron 1525 Notebook
My nuvi 1450 won't turn on and the garmin website updater won't reconize it hooked up to my computer even my computer won't reconize it.
I had the same problem with mine and got it working by doing the following while on the phone to Garmin. Plug your charger cord into the device and your computer (do not use a laptop, you need the higher current from a desktop for this). Hold the power button down for as long as it takes for the Garmin logo to display, this could be as much as 1 minute. As soon as the image shows on the screen, release the power button. If your Garmin isn't completely shot you will see it boot up.
If you have the Garmin Web Updater program on your computer, run it and update the operating system software to insure you have the latest greatest from Garmin. Once that is done, update your XML data files - they'll be on the list of updates if you need them. Once those are done you can update any voice or language files you'd like.
Lastly, leave your GPS plugged in at least an hour or two to give it a charge. Overnight would be better to insure your battery is really well powered up.
At this point your Garmin should function normally. The Garmin tech I spoke with told me some units start acting funky when the battery runs down too low and if it's REALLY dead it won't even take a charge or power up when you hook up your charger cord. Try holding the power button for as long as it takes to get a spark & you should be on your way. If not, call Garmin's support number for your locale & they're do their best to get you back up & running again.
Cheers, Jeff
Sep 01, 2011 | Garmin nuvi 1450 GPS Receiver
My phone turned off yesterday n now won't turn back on at all. What do I do I need to use it today
Try these few simple steps.
1. Remove battery.
2. Wait 30 seconds then replace battery
3. Plug in your phone charger.
4. Leave for 10 minutes.
Now try to switch on your phone.
If it doesn't switch on, take back to where it was purchased.
It may just be a charger problem but it could also be charger port or phone hardware.
Jun 17, 2011 | HTC Desire Cell Phone
Netgear wna 3100 won't install on my windows xp. I have uninstalled it 3 times. It won't recognize the adapter. Then it does. Then in the end it won't recognize it even though it's there...
My adapter constantly loses connection completely to the router and cannont be re connected unless i unplug and replug back in the USB port. What a joke!?
May 06, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
Car kit setting removal
"car kit" usually means the phone got wet...
unfortunately there is no way to fix it...
Jan 31, 2008 | LG VX9800 Cellular Phone
Motorola E815 - Battery Charger
I had the same problem but for some reason was able to use one of those Energizer battery chargers but no others!! I took it to Verizon and they cleaned the pins. Try using a toothbrush to clean it. That worked for awile then stopped. I took it to them againa and since it was still under warranty, they gave me a new one!
Aug 21, 2007 | Motorola Mobility E815
LG enV VX9900 Cellular Phone Logo
81 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
