Question about Pioneer DEH-17 CD Receiver
Unit will not operate after new car battery is installed
  • 376 Answers
Disconnect for atleast a few days, then re try...good luck
Posted on Sep 13, 2009
Automatic garage door not responding to any transmitters
Sounds like you need to reprogram all the remotes. Instructions should be with the new unit and even on the back of the unit up top .I just reprogrammed all of mine. When I installed my wall unit the others quit as well so I reprogrammed them. all.
Jan 01, 2016 | Building Materials
Tip
How to change a heater control unit/heater control ford puma
Ford Puma
What you will need:-
1.Phillips Screw Driver
2.Depending on what stereo system you have, stereo removal keys.
REMOVAL AND INSTALLATION
Climate Control Assembly/heater control unit/
Removal
1. Standard preparatory measures
Make a note of the radio keycode.
Make a note of the preset radio stations.
CAUTION:
Disconnect the battery negative lead.
2. Remove the radio.
3. Note:The control unit for the heating/air conditioning system, all operating knobs and the air distribution operating switch make up one assembly.
Remove the bezel/control unit.
1 Remove the screws on the top of the unit
2 Unclip the clips either side of the unit
Pull the bezel/unit forwards.
Disconnect the plug.
4. Unclip the air distribution shaft.
5. Remove the heater/air conditioning module and the fan operating switch.
Installation
1. Refit the components in the reverse order.
2. Install the radio.
3. Connect the battery ground lead.
Enter the radio keycode.
Reprogramme the preset radio stations.
Reset the clock.
Carry out a road test to enable the PCM to collect data.
4. Check that the heater/air conditioning operates properly.
on Jan 31, 2010 | Ford Focus Cars & Trucks
I have a Mitsubishi air conditioner model SRK50ZDA-S. The remote display seems to be working fine as I can change all of the settings as normal, but the wall unit doesn't respond to it. I can turn the wall...
The remote batteries could be defective or installed incorrectly. Try removing the batteries, pressing all buttons to eliminate the possibility of a stuck one, reinstalling batteries and testing operation. If no operation, the remote may have failed or there could be failure at the wall unit.
Jan 07, 2015 | Mitsubishi Heating & Cooling
G.P.S. will not turn on after replacing new battery
Even though the battery is new, it may need to charge fully before it will operate your unit. If the battery has been on the shelf for a while it may not have enough charge to work properly.
Sep 20, 2014 | Garmin nuvi GPS
Battery drain in 3.3L motor
It would appear that steps need to be taken to determine the current draw . it can not unless there is a circuit for it to do so . Disconnect the earth strap from the battery and insert an amp meter in the circuit . IF there is a circuit for the current you will read that current and that will point to what unit is capable of using that current with out serious effect. Low current (up to 3amps ) indicates lights so check boot light still on-glove box light on- interior light on-head light module faulty etc.; Higher draw then look for ECM working when it should be off--sensors operating from shorts __HO2s sensor ABS unit operating. Starter motors I would discount because if the solenoid was operating the starter would be spinning the motor. Check that the audio systems are not operational with out making noise .Units I would be checking would be automatic units that draw through a relay and a check for this would be to watch the amp meter for a change as each power wire to the relay/s was removed and re installed . IF you find a relay that causes a variance I would replace that module and recheck the current draw.
Mar 22, 2014 | 1988 Pontiac Firebird
Wont turn on with new battery in it
Is the new battery actually new? or is it a good one pulled from something else? This can make a difference. I have also found bad batteries on the store shelf.
It is also potentially old enough to have a layer of corrosion develop on battery contacts, Sometimes rolling the battery against each contact and then installing the battery is enough to cllean it to operational conditioin. Also make sure battery is installed in the correct orientation.
They also have a fairly short imaging tube life too but you would see some signs of life in the unit.
Mar 19, 2012 | Night Owl Optics Explorer NOCX3 Monocular
> the baterry is full
You battery is probably dead or about to, heating is normal when in charge status If you operating system is aging, you need a cleanup or a new OS installation
Jan 30, 2011 | Computers & Internet
Royal DS 2260,Installed new batteries, unit will not operate.
Have a new DS2260 in the package, never opened. Will sell the unit for 10.00 plus shipping.
Dec 05, 2010 | Royal 29546Y
Remote door opener does not operate with new batteries installed
When you change the battery you need to reprogram the unit.
Nov 21, 2010 | 1991 Cadillac Eldorado
How to install a coolant temp sensor in a 1995 ford escort engine 1.9 liter
REMOVAL & INSTALLATION 1.8L and 1.9L Engines CAUTION
Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  1. Locate the coolant temperature sending unit on the engine.
  2. Disconnect the sending unit electrical harness.
  3. Drain the engine coolant below the level of the switch.
  4. Unfasten and remove the sending unit from the engine.
  5. If the same sender is to be replaced, remove and discard the O-ring. To install:
  6. If reusing the old sender, install a new O-ring.
  7. Coat the new sending unit with Teflontape or electrically conductive sealer.
  8. Install the sending unit and tighten to 18–22 ft. lbs. (25–29 Nm).
  9. Attach the sending unit's electrical connector.
  10. Fill the engine with coolant.
  11. Start the engine, allow it to reach operating temperature and check for leaks.
  12. Check for proper sending unit operation.
2.0L SOHC Engines
  1. Disonnect the negative battery cable.
  2. If equipped, raise the car and remove the left-hand splash shield bolts.
  3. Loosen the petcock and partially drain the radiator.
  4. Lower the car, locate the sender and unplug its electrical connection.
  5. Unscrew the sender counterclockwise and remove it from the engine. Fig. 1: Unscrew the coolant temperature sender to remove it 90982g26.gif
    To install:
  6. Install the sender and tighten it to 13–17 ft. lbs. (17–24 Nm).
  7. Attach the sender electrical connection.
  8. If equipped, raise the car and install the left-hand splash shield bolts.
  9. Lower the car and fill the cooling system.
  10. Connect the negative battery cable.
2.0L DOHC Engines
  2. Loosen the petcock and partially drain the radiator.
  3. Locate the sender and unplug its electrical connection.
  4. Unscrew the sender counterclockwise and remove it from the engine. Fig. 2: On 2.0L DOHC (VIN 3) engines, tighten the coolant temperature sender to 89–124 inch lbs. (10–14 Nm) 90982g27.gif
    To install:
  5. Install the sender and tighten it clockwise to 89–124 inch lbs. (10–14 Nm).
  6. Attach the sender electrical connection and fill the cooling system.
  7. Connect the negative battery cable.
Jul 07, 2010 | 1995 Ford Escort
Pioneer DEH-17 CD Receiver Logo
42 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
