Question about KitchenAid KGSS907SSS Gas Kitchen Range
Are the cooling fans suppose to go on even when I'm just using the burners and not the oven
    Problem Solver:
  • 12 Answers
Yes they are so you don't over heat the controls.
Posted on Sep 14, 2009
Whirlpool cooling fan will not turn off ovens
There is a thermostat usually on the top or back of the oven which controls the cooling fan. When it cools down, the fan is supposed to turn off. I would say this thermostat has failed. Locate the thermostat and if its cool, the thermostat should be open circuit. If not, you will need a new one. Most spare parts centres should carry these. A generic or common oven cooling fan thermos will suffice if you cant get the genuine one. make sure the oven is off at the wall or the fuse box before you go into it.
Nov 19, 2016 | Whirlpool Ovens
Replaced igniter. Is it suppose to stay on the whole time the gas oven is on?
I assume you are talking about a glow bar type igniter. Yes they stay on as long as the burner is on but will cycle off when the oven reached the set temperature then come on to light the burner again when the oven cools back down to maintain the temperature.
May 10, 2015 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
What is wrong with our GE Profile Gas Range? After using the broiler and two burners simultaneously, the electronic controls go black. We can manually light stovetop burners but oven does not work.
On the back of the stove are 2 blower fans just under the cooktop. They are cooling fans to keep the controls from overheating. They are a long tube type fan and are left and right side. My guess is one or both are not coming on. They are controlled by a round disk temp control also under the cooktop. At a preset temp these fans should come on and keep all the control area cool enough to stop any damage. The fans need tested and maybe the temp control needs replaced.
Mar 23, 2015 | GE Profile 30" Slide-In Gas Range -...
Microwave fan goes on by itself without burners being on or used
It sounds like you understand that the exhaust fan is SUPPOSED TO come on when the microwave oven gets hot when exposed to the heat of the range below it, since you mentioned that no burners are turned on. So in that case, I'm pretty sure that you have a bad fan thermostat. It's usually located behind the control panel on the bottom (inside bottom) of the microwave floor.
Dec 26, 2014 | Kenmore Microwave Ovens
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
Aug 10, 2014 | Kenmore Microwave Ovens
In cabinet oven cooling fan does not work
it is the cooling fan if you have already replaced the thermal fuse on the back then replace the fan also shop around that price for the fan sounds high
Apr 05, 2010 | Whirlpool RBS305PDS Electric Single Oven
Continuous squeeky noise from underneath the burners.
Permanently? A fan will come on when using fan forced, another fan will come on(approx 5-10 minutes) later, which is the cooling fan,and can run for up to an hour after turning off. Turn off oven at mains to determine if it is electrical related fault.
May 23, 2009 | Smeg 24 in. DWF614SS Stainless Steel...
Oven fan does not turn off
assumming its the cooling fan( which is only supposed to run to cool the controls). as per my diagram which wasnt very clear there is no thermostat controlling the fan , looks as though it gets its pawer directly form control board/clock assy , perhaps a relay is stuck closed, i would look for t he wire diag on the back of unit and trace back the fan wires perhaps theres a thermostat not listedn my diag.
Nov 09, 2008 | Maytag MES5775BAS Stainless Steel Electric...
Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Apr 05, 2008 | GE JTP15 Electric Single Oven
Turning off oven.
The fan only comes on in the back of the oven when convecting and Automaticaly turns off when you open the door. The exhaust fan coming from the front stays on for qutie a while, maybe 2 hours or so till the oven cools. I think it is just a function of the oven. A good thing in the winter but uses a bunch of airconditioning in the summer
Oct 23, 2007 | Electrolux ICON 30 in. Double Wall Oven
KitchenAid KGSS907SSS Gas Kitchen Range Logo
118 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
