I got a 1995 30ft Conquest by Gulf Stearm. The air unit on top is a coleman 13,500btu. The model and serial #'s can't be seen. Where the main power supply connects in the control box shorted out and burnt the pc board. The pc board is a #7330B331. What is the part # for the complete control box assembly I need to be looking for and where would be the best place to get one? You can email me at chambers.willie@gmail.com
  • 534 Answers
Try a r/v dealer in your area explain to him what you have and he should have access to the type of unit installed on that particular gulfstream r/v since they are installed as a standard unit at the factory Good Luck
Dave
Posted on Sep 16, 2009
I have a coleman suncutter model 7448-801 and the fan motor was replaced but instead of it blowing out the top of unit it is drawing in from top and trying to blow out thru the coil is this accurate or is...
I have never seen one that doesn\'t suck air in through the coil and blow out the top. My guess is that the double shafted motor was installed backwards.
May 09, 2014 | Heating & Cooling
Water heater elements for 2006 conquest trailer
Remove the old element. Take note of the water heater make and model, i.e. Suburban SW6DE or Atwood GC6AA. You can find the replacement at your local RV parts department. I have even seen them at Lowe's. Or you can buy one online.
Apr 19, 2014 | Gulf Stream RVs
Need to know the tonnage of this unit
You have a 48,000 BTU or 4 ton unit.
Oct 10, 2012 | Coleman Heating & Cooling
Need fan switch for coleman a/c model 6734B917
Any RV dealer should be able to get you one, if not try inquiring here.
http://www.rvcomfort.com/rvp/contact.php
May 24, 2012 | Coleman Mach 3 Plus Roof Mount A/c Unit W/...
How can I find the model number for the fan. I have a 1999 avion with a coleman mach air the fan makes a lot of noise.we oil it but it quit last night and I think it may need replacing.
The model number of you upper unit which can be seen from inside on bottom of unit behind filter etc at ceiling, will give enough info for replacement fan. Here's a good spot to find part #'s etc for your unit.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Aug 20, 2011 | Coleman Mach III Air Conditioner
Hello. I would like to know how many ton my Coleman Central Air Unit is. The model number is 'ERCS0241BBB". The serial number is "WOD7699360". Thank you.
This is a 2 ton A/C I got that from the 24 in model number it means 24,000 btu which equals 2 tons cooling. If this helps please rate me and do a testimonial.
May 23, 2011 | Coleman Heating & Cooling
Where can I find a manual for my coleman cam II central air conditioner for a mobile home? I recently purchased the mobile home and would like to know what steps to ntake to make it work at its best. ...
Check the website for Coleman/Intertherm for a manual, you will need the model and serial numbers of the unit. The filters for these typically sit on top of the unit, some come with frames, some lay directly on the coil. If you can't find a manual on the website or by contacting the company, check the yellow pages some towns have a mobile home supply house that would be able to help.
Aug 30, 2010 | Coleman Heating & Cooling
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
