Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
When i go to start the ski doo it doesn't want to start, but when i pore gas in the spark plugs it fires burns the gas then dies
First of all check your fuel filter and then the fuel line,it can be the fuel line inside the tank (if it do it only when in low gas)it can be the fuel pump or the suction line from the motor base i hope it will help
Posted on Sep 20, 2009
    Problem Solver:
  • 10 Answers
You will likely need to take your carbs off and clean them.After sitting for the summer the gas evaporates and plugs up small holes in the carbs
Posted on Dec 06, 2009
My 2002 ski doo summit 800 will not start
check spark, check fuel, are the plugs wet, does it start on spray starting fluid?
Dec 11, 2016 | Winter Sports
08 ski-doo gtx 500ss lost power to one cylinder, lots of spark, plug dirty. Blown piston? Cause?
check it's getting fuel to that cylinder, if so would suspect piston ring or leaking valve. burning blue smoke from exhaust is a clue.
Mar 02, 2015 | Cars & Trucks
Why does my 800 sxr jet ski engine runs full throttle and keeps running even after I pulled the spark plug caps?
dirty carbs !
reeds broken will spit back through the carbs !
crank seals worn can let engine run away !
Jul 07, 2014 | Boating
What is wrong when you push reverse button and the engine dies ?
we had a sled that used to do that all the time. ended up doing a tune up on it and it stopped dying. try changing the spark plugs and double check there are not vacuum leaks into the motor or intake manifolds.
also if the carbs are dirty then they may not be idling high enough to restart when it cuts out for a second to go into reverse....
May 19, 2014 | Winter Sports
2009 SUMMIT SKI DOO WILL NOT START
Ski Doo's are known to have BAD KILL SWITCHES
DPM going bad
Dec 24, 2013 | Ski-Doo 2009 Summit Everest 146 800R Power...
Ski-doo won't stay running or idle
sounds like it could be the air to fuel ratio. if it only want to run with the choke on. I would say to make sure all your nuts and bolts are tight and that you check the gaskets in between the carb and the motor. another thing you could do is get a can of starting fluid and spray it around the carb while the motor is running (do not spray it in the carb)if the idle changes or if it dies you need to replace gaskets.
Dec 19, 2013 | Motorcycles
My riding mower will not start,it turns over
remove your breather pour just a little gas directly into the bowl of the carburator less than a once then try to start it. if it starts and runs for a few seconds then dies then its not getting gas and most likely a problem with the carbuator. if it doesn't start at all by doing this then its not putting fire to the spark plug there are many problems for this so after you try this and your problem is in the firing of the spark plug let me know and i will give you a few things to check for this problem.
Apr 27, 2012 | Garden
Engine turning over but no start...
Is it getting spark? remove one spark plug wire and put a spark plug in it, hold the body of the plug against an unpainted metal part of the engine or body with an insulated tool (like a plastic handled screwdriver) and get someone to wind the engine over. You should see spark at the plug. If not, check to see if the igniter module is switching the coil correctly (might want to search on the net for this procedure, too hard to explain here). Probly best to just replace the igniter module anyway with the age of the vehicle.
Oct 25, 2008 | 1988 Acura Legend
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
236 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
