Question about Mitsubishi WS-48613 48" Rear Projection Television
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
Hi, the tv was working fine & it has barely been used since '99. I haven't used it in forever. I plugged it into the wall outlet & it won't turn on. The green light in front just clicks on & off 1 second. The TV won't turn on though. The power button on the TV does the same. Is it because I don't have the TV Cable plugged in? I doubt that. What happened? I don't know what to do?!! Please help me. Is there a reset button or something??
  • 4 more comments
  • giggles99 Dec 12, 2007
    Thank you ctf1800!!! I checked the error code & it's 23=Horizontal deflection failure. What should I do now? Can I fix this myself easily? I don't want to spend hundreds of dollars on a technician. The Tv's only worth like $200 now. Please let me know if there's anything i can do!
    Thank you!
    Annie
  • giggles99 Dec 13, 2007
    HI ctf1800! Wow! Ur so smart. I don't know what language ur speaking. :( hehe. Is it possible to help me locate all that stuff easier? I don't know which part it is. I don't know how to locate it. Is there a picture or something somewhere where you could locate that stuff for me? I don't know where to start except to open the back of the tv. Are all those things on the board? And how do I know if it's shorted? If it is shorted...how do i replace it? Is it easy & cheap to buy that piece?
    THANK YOU SOOO MUCH!!!
    annie
  • giggles99 Jan 11, 2008
    Hello ctf1800! Happy new year! Thank you for your detailed advice! I called a tv repair guy & told him the error code 23 & he said it's probably a coolant leak because this model gets that problem a lot. I don't want to pay $50 just to come look at it. I didn't see any leaks on the board when we opened it.
    He also said that there is no replacement if it is because this model is discontinued.
    Another guy said that I have to replace the power supply. I'm confused.
    I'm getting sad. This tv is like new! :( I want to try to fix it myself, but I still don't understand how to find the parts you're telling me to look for. I'm a total dummy. I don't know what capacitors, etc. are. If I take a picture can you point out what to do?
    Thank you!!!!!!!!
    Annie
  • Anonymous Apr 03, 2009
    I have no power or power lamp at all when pushing the power button.
  • Anonymous Mar 15, 2014
    Mitsubishi 50" lg rear projection tv wont turn-I gave this TV to a coworker and she said no lights or anything will work. It worked the night before we gave it to her. Would something have happened in the move? It was not put on it's side.
    President:
  • 4,402 Answers
Most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Posted on Dec 11, 2007
  • 3 more comments
  • Cary Farah
    Cary Farah Dec 12, 2007
    Depends on how good you are at soldering and unsoldering,
    First check:
    CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT
    POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND
    C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
    then:
    the horz. defection is the horz output transistor and and the high voltage transformer/splitter i would check the horz transistor first. see if it's shorted
  • Cary Farah
    Cary Farah Dec 13, 2007
    the DY connections is the connector going to the tube 4 heavy colored wires there is a set of three, this would only require soldering skills to resolder these connectors they are on the main board, i would replace the capacitors no matter what these you can get at radio shack, the out put transistor you will have to know how to work a multi meter to test for short cant help you there, but you could get the part online at like Mcm electronics (capacitors too) high voltage splitter would have to get at a manufacture reseller site
  • Cary Farah
    Annie after thinking about this maybe the best thing to do would be to send it into PTS for repair, however there is high voltage in the tubes and on some boards.
    http://www.ptscorp.com/
  • Cary Farah
    Cary Farah Jan 11, 2008
    Annie go to these sites they will show you what to look for
    he shows what a cap is on this link
    http://www.fixya.com/howto/h159332-mitsu...
    • this is convergence ic's
    http://home.earthlink.net/~oleg.filippov...
    ttph://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
  • danzforme Jul 17, 2012
    Thank you, I held the buttons and got error code 12. I pressed power and the tv started up. Took a couple tries but it did come on. Wavy lines for a the first few minutes though.
Hi...I try the error code check..menu and input...held for over 30 seconds and it just flashes green. anyone have any idea why I am not getting a read out...could the power supply be bad??
Posted on Dec 29, 2007
2 Suggested Answers
mattozan
  • 555 Answers
SOURCE: Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
Here are the answers for giggles99':
One
Two
Three
Posted on May 16, 2008
Got a Mitsubishi vs-8070, everything works fine then the screen turns off after about 15 minutes sound still works fine. Help.
Does this unit have a projection bulb in the back end of the set? Just based on my experience with a friend's 65 inch rear projection TV, there might be an indicator light on the front panel that may blink if the rear projection bulb is failing. If there is a failing bulb it could account for the screen going black with everything else just fine, after the bulb gets heated up in 15 minutes.
Oct 15, 2014 | Televison & Video
Sylvania TV - volumn is so low we must turn it all the way up and even then can barely hear on some stations. We have dish tv.
The Dish receiver may have a volume function that is causing the problem. Use the Dish remote to increase the volume and see what happens.
Mar 07, 2009 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi 80 inch rear projection tv
I will be getting one of these tv's in the next couple of weeks and I will be parting out all of the internal electronics, tubes and lenses. drop me an email. kievsavoie@hotmail.com
Jan 31, 2009 | Mitsubishi VS-8087 80" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi 50 inch projection tv
you probably have a problem with the convergence board.
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-5046
i have a 50in mitsubishi tv model vs5046 the screen protector is crack the tv works fine but need to know where can i purchase a protector or its there a number. also how much will this cost.
Oct 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Video
What kind of input are you using
Nov 05, 2017 | Mitsubishi VS-5043 50" Rear Projection...
Tv shuts off
You could have a problem in the sweep or main power supply, Bad capacitors on the DM module, they will be all grouped together and have swollen tops, Coolent fluid leaking out of one of the CRT's. If you have no electronic or solid state repair experience, please get a pro to assist you in this repair. Good Luck
Apr 03, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
6,249 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
