Question about Toshiba Satellite A100-S8111TD Notebook
Im trying to turn to computer on but when i do it say to enter a current password and i didnt put it there
  • 125 Answers
Unfortunately, someone probably did change your settings. If not, the profile could have become corrupted and changed. Do you have more than one login for your computer? If so, log in as the Administrator and create a new profile user and transfer the files and programs over to it.
Posted on Sep 12, 2009
Forgot log on password
Troubleshooting lost or forgotten passwords:
  1. Make sure Caps Lock is turned off.
  2. For Notebook computers, make sure Num Lock is turned off.
  3. If the password has special characters in it (examples: ! * $ # +), make sure you press the SHIFT key (not the CTRL key) when entering the password.
  4. Try these common default passwords:
    • Administrator
    • Password
    • Leave password field blank
  5. If you are unable to correctly enter the password after using the previous steps, the only option is a format and reload of the computer with all data removed from the drive.
Aug 02, 2012 | Gateway GT4022 PC Desktop
Ok im trying to start my comp a window pops up i must enter username and password where can i set or reset HELP IM CLUELESS
just enter your current password than you can change it its a feather in windows that wll make you change your password every 60 days
Jan 17, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
L355D-S7815 when turned on it is asking for current password. I have no idea what this is.When i put in my password and hit enter, it goes back to enter password. after about 3 or 4 tries it shuts off.
it looks like your computer haves a password protection for startup try to reset the bios or try to type one of these passwords Toshiba 24Banc81 toshy99
Mar 13, 2010 | Toshiba Satellite L355D-S7815 Notebook
I get a screen durning boot that says, ENTER current password.
Good morning! I think your OS was corrupted, I suggest to reinstall your XP O/S thru your CD drive but please check your IDE/SATA cable connections. best regards.
May 09, 2009 | Computers & Internet
Need to get a password reset
Have you tried just pressing enter??
If there is no password then this should work.
May 08, 2009 | ASUS Eee 4G Notebook
When you turn the macbook on it asks for a username and password and i recently changed it and didnt write it down is there anyway of getting passed it
Did you choose a security question? (helps recover password)
OR Try This (taken from another forum)
"Try this
Although there's no real way to recover a lost root password, you can change the root password even if you do not know the current one. You must have physical access to the machine in order to accomplish this task.
Click Restart at the login window
While the computer is restarting, hold down "Command-S" until you see text scrolling through the window.
This boots the computer into single user mode.
At the Localhost% prompt type:
/sbin/mount -uw //sbin/SystemStarter
You will then see various services starting up.
When the Localhost% prompt reappears, type:
passwd root
It will then ask you to type the new root password twice, so do so.
After entering the new password, type:
reboot
At the login window, enter username root wih the new password.
Once you are connected, you can use the Multiple Users application (/Applications/Utilities) to change your normal user's password, or create a new user account."
Apr 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
1. My ideapad Y430 easy cam doesnot working after i reinstall windows vista ultimate. Not i cant use it for my password. 2. I also try to partition it into four but it doesnot support i can have only two...
this is all I can offer in your situation.....one option is to..use the...
Novo button
This button functions as a reset button; use with caution. Press the
1. Novo button to enter the main interface of OneKey Recovery while the
power is off. You can use OneKey Recovery to restore the primary
hard disk partition (usually drive C) back to the factory default
configuration, including the operating system and the software on it.
Attention: Once done, the system can no longer return to its previous
state. All data on the primary hard disk partition (usually
drive C) will subsequently be lost. So make sure all
important files on the primary hard disk partition have
been backed up onto another hard disk or USB hard disk
drive before this operation.
For details, see “OneKey Recovery4.65 User Guide
2. For the camera check out these key functions....
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
3. And for the password...here you go....
Using Passwords
Using passwords helps prevent your computer from being used by others.
Once you set a password and enable it, a prompt appears on the screen each time you power on the computer. Enter your password at the prompt. You cannot use the computer unless you type the correct password.
Make sure that only authorized individuals access your computer.
Establishing different kinds of passwords requires that other possible users know the proper passwords in order to access your computer or your data.
As many as three passwords might be needed for your computer: the Supervisor password, the User Password, and the hard-disk drive (HDD) password. When the Supervisor password is set, only the Supervisor password entitles you full control of the computer.
• User password
If a user password is set and Password on boot is enabled, a password prompt appears when you turn on the computer. Unauthorized users cannot get access to configuration data.
You can also use the user password to enter the BIOS Setup Utility, but once the Supervisor password is set only a part of the options can be set.
• Supervisor password
With a Supervisor password, you can get full control of the computer. It also can be used as a power-on password, the same as the User password. Also, when you enter the BIOS Setup Utility with a Supervisor password, you are entitled to set all of the options.
• Hard disk (HDD) passwords
Once an HDD password is set, you need to enter it to get access to the hard disk. You can set the HDD password through either the User Only selection or the User + Master selection in the BIOS Setup Utility.
Note: If you set passwords through the BIOS Setup Utility and you put your computer into sleep mode by pressing Fn + F1, the following describes the behavior of the computer when you bring it out of sleep mode:
• You are prompted to type the Windows log-on password rather
than the User password to resume operation.
• If an HDD password is assigned to any hard disk drive, the hard
disk drive is unlocked automatically when you resume operation.
To set a User Password:
1. Turn on your computer. Press F2, while the initial screen is displayed.
The BIOS Setup Utility screen opens.
2. Select Security, using the cursor directional keys.
3. Select Set User Password, and press the Enter key. The Set User Password window opens.
4. Choose your user password, which can be from one to eight
alphanumeric characters in any combination. Type it in the Enter New Password field.
5. Press the Enter key once to move to the Confirm New Password field. Retype the password you just entered to verify it.
6. Commit your password to memory, and press the Enter key.
7. Press F10 to exit.
8. Select Yes in the Setup Confirmation window.
Changing or Removing the User Password
To change the password, do the following:
1. In the Enter Current Password field, type your current password.
2. In the Enter New Password field, type a new password; then retype it to verify.
To remove the password, do the following:
2. Leave the Enter New Password field blank, and then press the Enter key twice.
Note: Make sure the Password on boot is set to Enabled if you need the password protection at power on.
To set a Supervisor Password:
Only a system administrator will be able to perform this procedure.
2. Select Security using the cursor directional keys.
3. Select Set Supervisor Password, and press the Enter key. The Set Supervisor Password window opens.
4. Choose your supervisor password; it can be from one to eight
5. Press the Enter key to move to the Confirm New Password field.
Attention: You might want to note your password and keep it in a
safe place. If you forget your supervisor password,
Lenovo can not reset your password. You must take your
computer to a Lenovo reseller or a Lenovo marketing
representative to solve this problem. Proof of purchase is
required, and a fee will be charged for parts and service.
The next time you open the BIOS Setup Utility program, you will be prompted to type your password to proceed.
Changing or Removing the Supervisor Password
1. In the Enter Current Password field, type the current supervisor
password.
2. In the Enter New Password field, type the new supervisor password; then retype it to verify.
password.
Hard Disk Passwords
Two types of the hard disk passwords help protect the information stored on the hard disk:
• Hard disk user password
• Hard disk master password, which requires a hard disk user password If User only is selected and a hard disk user password has been set, but no hard disk master password has been set, the user must enter the hard disk user password in order to gain access to files and applications on the hard disk.
If User + Master is selected you need to set a master password and a user password both as the Hard Disk Password. Either of the two passwords can be used to get access to the Hard disk. Any change or removal to the master password deletes the user password.
To set a hard disk password:
Print these instructions.
3. Select Built-in HDD1 Password Select, and press the Enter key. A window for selecting User Only or User + Master opens.
I will send the rest in the comment section..hope this helps in some way...the Fang.
Mar 07, 2009 | Lenovo 3000 Y410 Notebook
Pls help
hi! good day! try this
2767*3855# - FULL E2P RESET
*2767*2878# - CUSTOM E2P RESET
#*7337# - UNLOCK
*2767*688# - UNLOCK
Apr 11, 2008 | Samsung SGH-e315
Samsung e315 one sim only
hi! good day! try this code
#*7337# - UNLOCK
*2767*688# - UNLOCK
Toshiba Satellite A100-S8111TD Notebook Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
