Question about Refrigerators
Need pressures for refrigerator
I need to recharge a system with a new compressor, and can not find any information on proper operating pressures. It is a Whirlpool ED27PEXHW01.
  • 2 more comments
  • zoomzoomac Sep 13, 2009
    I was looking for what # the guages will show when hooked up. Thanks
  • Mike Smith
    Mike Smith May 11, 2010
    Or plus 10 on the low side .
  • Mike Smith
    On the tag which has the model and serial number , it will tell you how much refrigerant to put in the system ( in english ) .
  • Luis Gonzalez Sep 12, 2013
    10 with -5 ?
  • Refrigerators Master
  • 1,606 Answers
As long as you know you evacuated completely , then the high side doesn't matter too much . The low side should read about +10 , if your using R134 .
Posted on Sep 13, 2009
My 99 tahoe a/c is not working and is recharged properly. The clutch does not engage on the compressor and the compressor is new. What can the problem be
if you did the recharge then check the gas pressures as there are two main switches that control the ac operation
one is a high pressure switch which stops operation if there is excessive gas or a blockage and the other is a low pressure switch which stops operation if the gas has leaked out
did you have the ac system checked for leaks before gassing it or replacing the ac compressor
lastly some systems have a relay that controls the ac and that can fail
Jul 09, 2016 | Cars & Trucks
What do I look for when low refrigerant pressure is displayed on control board
A good service technician. Low refrigerant pressure is a sign of a refrigerant leak in the system, or a failing compressor. It will need to be repaired and the system recharged to get it working properly.
Jun 29, 2015 | Refrigerators
I have replaced defrost heater and defrost sensor in fridge but top still not cold and icing up at evaporator samsung srs584dp
It sound like your system is low on refrigerant. After you make sure the condenser is clean, and if you have a fan on the condensor that is is operating, check the temperature of the smallest refrigerant line coming out of the compressor about 5 or more inches from the compressor. This is the high pressure line and during normal operation should be around 140 degrees when fully charged. It is my experience about 5 percent of the mass produced refrigerators coming into this country is not charged properly and can cause the symptoms you describe. About 1 percent develop leaks and lose refrigerant. If your line is warm to the touch or barely warm to the touch, you will need to have your system leak checked and recharged by a competent refrigeration tech.
Hope this helps.
Dec 10, 2014 | Samsung Refrigerators
How to recharge a.c. on a 2004 buick rendezous
Have you tried that stuff called "AC PRO"? It comes in a can with a pressure gauge and there are videos on youtube that show how to use it.
Now if you've replaced a compressor or another part of the AC system, you'll need someone to use a vacuum pump on the system to remove all air and moisture, and then they can recharge it with fresh R-134 refrigerant to the proper specification, which whoudl be listed under the hood on a sticker. This sticker also shows vehicle engine and emission information.
Jul 02, 2014 | 2004 Buick Rendezvous
AC does not work 2000 Ford windstar
first thing check AC compressor fuse.the AC compressor clutch should engage when you turn on airconditioner if AC compressor dont come on and fuse okay compressor clutch is open or low on refrigerant you need check your AC refrigerant low pressure side and high pressure side need a manifold gauge set. best let garage check out AC system could need system recharged or could have leak in the system.
Jun 19, 2013 | Cars & Trucks
On the dashboard of my 99 deville it says a/c off low refrigerant. how do I turn the ac back on to recharge ? thank you ...
You will need to recharge it to get it to come back on, it has a pressure switch that will prevent operation until the level is brought back up to normal.
Jun 26, 2011 | 1999 Cadillac DeVille
I need to know where the recharge port is to recharge A/C on a 1999 Ford Expedition
Your A/C system will have two service ports, there isn't any "recharge" ports. You add refrigerant to the LOW side only. Prior to adding any refrigerant, you need to check the system pressures with a manifold gauge set. If the system has enough charge and there is another issue, adding refrigerant can make for worse problems. Automotive A/C is best left to the right person with the proper equipment to service them. If you follow the lines from the compressor, the LOW side will be the smaller diameter of the two service ports.
Mar 31, 2011 | 1999 Ford Expedition
Air condition is blowing hot air.
If you can hear or see the compressor operating, change the thermostat and ensure there's sufficient coolant in the system. If the compressor will not operate when you turn on the air conditioner, you most likely have a leak in the system and have lost sufficient refrigerant to operate it. Most compressors need a minimun of 20lbs of pressure to operate. A lack of refrigerant will prevent the compressor from operating as a protective measure. Although it's possible to recharge the system yourself (products are available to both diagnose the leak and recharge the system) if you're unfamiliar or uncomfortable with doing it yourself, it should be serviced at an authorized service station that does AC work.
May 13, 2010 | 2006 Chrysler PT Cruiser
My air is blowing warm can i use 1342a?
The real answer to your question is yes, the kit may work. Here is why you shouldn't use a recharge kit: Theoretically, your vehicle's refrigerant (R134a) should last forever. Your AC system is a sealed unit and the refrigerant never gets used up. The only way you can lose refrigerant is by it leaking out of the system. However, if your refrigerant can leak out then air and contaminates can get in. This is bad. A recharge kit simply injects refrigerant into the system. It doesn't evacuate the system of any air and contaminates.This is critical. Your AC system should be hooked up to an AC machine in order to evacuate out all of the air and contaminates in the system. The machine will then hold a vacuum on the system to verify its integrity.Finally, the machine is able to inject new compressor oil that also contains a dye that will enable the leak to be located. If you use that recharge kit, you stand the chance of over pressurizing the AC system and causing premature compressor failure. This can be very expensive. Paying a reputable shop to evacuate and recharge your AC system is much less expensive. If your AC system hasn't operated in over 6 months, it's especially critical that you have the repair to your AC system performed correctly. Your AC system's seals may have dried out and the new compressor oil will be critical in helping to recondition those seals or the seals may need to be replaced. Good luck and hope this helps. keep me posted if you need help to recharge the system.
Jun 05, 2009 | 2000 Ford Crown Victoria
''does a new radiator need refrigerant added to it''
You need to replace the condensor, then take it to a shop to have the a/c system evacuated and recharged to purge moisture because the system was opened. That will cost around $150. You do not need to replace the receiver/dryer/suction accumulator even though they will tell you that you do.
go to car-part.com to find prices of condensor from salvage yards. Page with asterisk on it is the lowest priced part.
The Refrigerant Cycle
During stabilized conditions (air conditioning system shutdown), the refrigerant is in a vaporized state and pressures are equal throughout the system. When the A/C compressor (19703) is in operation it increases pressure on the refrigerant vapor, raising its temperature. The high-pressure and high-temperature vapor is then released into the top of the A/C condenser core (19712).
The A/C condenser core, being close to ambient temperature, causes the refrigerant vapor to condense into a liquid when heat is removed from the refrigerant by ambient air passing over the fins and tubing. The now liquid refrigerant, still at high pressure, exits from the bottom of the A/C condenser core and enters the inlet side of the A/C evaporator core orifice (19D990).
The A/C evaporator core orifice is the restriction in the refrigerant system that creates the high pressure buildup in the A/C evaporator core (19860) and separates the high and low pressure sides of the A/C system. As the liquid refrigerant leaves this restriction, its pressure and boiling point are reduced.
The liquid refrigerant is now at its lowest pressure and temperature. As it passes through the A/C evaporator core, it absorbs heat from the passenger compartment airflow passing over the plate/fin sections of the A/C evaporator core. This addition of heat causes the refrigerant to boil (convert to gas). The now cooler passenger compartment air can no longer support the same humidity level of the warmer air and this excess moisture condenses on the exterior of the evaporator coils and fins and drains outside the vehicle.
The suction accumulator/drier (19C836) is designed to remove moisture from the refrigerant and to prevent any liquid refrigerant that may not have been vaporized in the A/C evaporator core from reaching the A/C compressor. The A/C compressor is designed to pump refrigerant vapor only, as liquid refrigerant will not compress and can damage the A/C compressor.
The refrigerant cycle is now repeated with the A/C compressor again increasing the pressure and temperature of the refrigerant.
The A/C cycling switch (19E561) interrupts compressor operation before the external temperature of the A/C evaporator core gets low enough to cause the condensed water vapor (excess humidity) to turn to ice. It does this by monitoring low side line pressure. It is known that a refrigerant pressure of approximately 210 kPa (30 psi) will yield an operating temperature of 0°C (32°F). The A/C cycling switch controls system operation in an effort to maintain this temperature.
The high side line pressure is also monitored so that A/C compressor operation can be interrupted if system pressure becomes too high.
The A/C compressor pressure relief valve (19D644) will open and vent refrigerant to relieve unusually high system pressure.
Item Part Number Description 1 19E762 A/C charge valve port (low side) 2 19E561 A/C cycling switch 3 19C836 Suction accumulator/drier 4 19703 A/C compressor 5 19D644 A/C compressor pressure relief valve 6 19D594 A/C pressure cut-off switch 7 19E762 A/C charge valve port (high side) 8 19712 A/C condenser core 9 19D990 A/C evaporator core orifice 10 19860 A/C evaporator core 11 — Low pressure vapor 12 — High pressure vapor 13 — Low pressure liquid 14 — High pressure liquid
  1. Connect the R-134a A/C Refrigerant Center to the low- and high-pressure service gauge port valves.
  2. Evacuate the system until the low-pressure gauge reads at least 99.4 kPa (29.5 in-Hg) (vacuum) and as close as 101.1 kPa (30 in-Hg) as possible. Continue to operate the vacuum pump for a minimum of 45 minutes.
  3. Turn off the evacuation pump. Observe the low-pressure gauge for five minutes to make sure that the system vacuum is held. If vacuum is not held for five minutes, leak-test the system, service the leaks, and evacuate the system again.
  4. Correctly oil match the system to verify that the correct amount of refrigerant oil is present in the system. For additional information, refer to Refrigerant Oil Adding in this section.
  5. Charge the system with the specified weight of refrigerant and refrigerant oil.
  6. When no more refrigerant is being drawn into the system, start the engine and select MAX A/C operation. Set the blower motor speed to maximum and allow the remaining refrigerant to be drawn into the system. Continue to add refrigerant into the system until the specified weight of R-134a has been added. Close the charging cylinder valve and allow the system to pull any remaining refrigerant from the hose. When the suction pressure drops to approximately 207 kPa (30 psi), close the charging hose valve.
May 14, 2009 | 1995 Nissan Maxima
Refrigerators Logo
317 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
