Question about LaCie F.A. Porsche (301177) Hard Drive
Lacie extern. hard drive is recognized, but I can't access files
My computer is recognizing my external hard drive, but I can't access the files. My Lacie 250 GB external hard drive by F.A. Porsche (item #300728) is showing up in "disk management" and it says it's healthy, but it also says there's about 232 GB of free space, which is more than there should be. I don't see a file system listed for my Lacie drive though, there's a blank space instead of either FAT32 or NTFS. The drive is about 4 years old and I have music, documents, and pictures on it. Praying that it's not all lost. I also can't access the "my computer" view from the start menu when the external hard drive is plugged in. Any help would be greatly appreciated.
  • 32,281 Answers
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Posted on Sep 13, 2009
My computer no longer recognized my hard drive
did your computer device manager recognized your external drive? did disk management recognized you external drive? let me know.
Apr 05, 2010 | LaCie (300770) 250 GB Hard Drive
How do I view the files in my LaCie backup folder? The show hidden files/folders option is checked and I still can't see anything.
It appears you have an external hard drive. It should connect to your computer with a USB cable. Make sure the external hard drive is turned on and running before you connect the usb cable to the computer. Some external hard drives have an on/off switch and some do not. you can hear it running if you put your ear close to the case.
When you plug it in, wait a few minutes and the computer should indicate that it has recognized it. (sometimes this does not happen) In any case, after a few minutes, open My Computer (Computer, in Windows 7) (sometimes referred to as Explorer- NOT to be confused with Windows Explorer which is an internet browser). You should see a list of recognized drives including your external hard drive. Doubler click on it and you should be able to see your files.
If it doesn't show in Explorer, the computer might be trying to assign a drive letter to it that is already taken. To fix that, go to Control panel, Administrator Tools, Computer management, Disk Management. You should see your external drive listed and you can assign an unused drive designation to it there. You should then be able to go back to Explorer and see it. You might have to refresh the Explorer screen.
Dec 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 300790 that my Mac won't recognize
the Mac may not recognize it if it is formatted with NTFS. I believ most Macs can read FAT32 and other formats but not NTFS. You could hook the drive up to a modern PC, transfer the files there for a while, format the external drive to FAT32 and copy the files back to the drive. The Mac shold read them now,
Sep 21, 2009 | LaCie d2 Extreme (300790U) 250 GB Hard...
First time trying and i cannot access my data. This is the first time I tried to pull it up.
USB is very finnicky. Shut off your computer and external drive. Unplug the USB cord from one end (which ever is easiest). Turn on your computer. When windows is up, plug in USB cable. Turn on USB drive. Windows should recognize the USB ox and drive and attach the extra drives. But, you must have windows millenium or newer. Or you will need USB drivers for the external USB box.
May 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
External hard drive
I just worked through this same issue with LaCie tech support and they fixed it- it was a bad power supply. Fortunately I had another LaCie drive and when I plugged the power supply from that one in to the "misbehaving" drive, everything booted up fine.
Sep 20, 2008 | LaCie (300770) 250 GB Hard Drive
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
May 29, 2008 | LaCie (300728U) 250 GB Hard Drive
Can't access my lacie external hard drive
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Jan 09, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie F.A. Porsche (301177) Hard Drive Logo
2,389 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
