Question about Mtd Garden
Tighten belts on my Yard machine ride on lawn mower
  • 124 Answers
There is rarely any adjustment to tighten the belts on a riding mower. The belts are tensioned by an idler pulley which is controlled by a idler pulley spring. Almost all riding mower belts must be accurate to the hundredth of an inch or no less than accurate to 1/8th inch. It is very rare for a belt to be in full inch increments. This is why automotive or general purpose belts will not work on a riding mower. I know it is tempting to try to get by with a $10 belt rather than spending $35 or more for the correct belt. Trust me, you will only waste your money trying to get by with the inferior belts. Riding mower belts and extra heavy duty and generally will not stretch at all. Generally they will have 5 or more strands of a Kevlar type material so that stretching is virtually non existent. If the belt will not tighten then it is most likely not the correct belt. If the belt is in fact the proper belt and still is too loose, then you should look for pulley wear or weak tension springs. Metal pulleys do wear and tension spring do loose tension.
Posted on Sep 14, 2009
What sizes are the drive belt and mower belt on a 1999 agway mtd riding mower with a 12.5 hp briggs?
go to any lawn mower shop they will tell you and get you your belts 45.00 to 60.00 for a belt
Aug 11, 2014 | Mtd Yard Machines 38-Inch 12.5 HP...
How to tighten belt on kobalt lawn mower
Is the belt worn or stretched? You may need a new one
Also make sure all the levers and rods that work the pulleys are oiled as a dirty and dry workings will not tighten properly.
May 26, 2014 | Yard Machines Garden
Yard machine riding lawn mower won't crank over
You might want to refer to this Yard Machine Riding Mower Manual for troubleshooting techniques.
Feb 02, 2013 | Garden
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
I changed belt on deck blades and now the blades will not turn.can u help
is the belt turning on the pullies but there not turning or is the belt not turning either
and you may not have the belt idler on right that is what is used to tighten the belt up
Jul 24, 2011 | Yard Man Yardman Riding Lawn Mower 38in...
Replaced deck belt and it keeps coming off,whats wrong?
The belt tensioners on top of the deck need adjusted, or you make have to adjust the pulleys to tighten the belt. Sometimes if you have the deck lowered to low to the ground, uneven terain can cause that. If you have everything adjusted correctly, simply raise the deck another notch and mow.
Aug 09, 2010 | Yard Machines 155 Torque Briggs Stratton...
Chews up belts quickly
Usually this is caused by improper belt routing. You didn't say which belt. For example if the belt is on the outside of one of the pins or metal guides that keeps the belt in the pully. Or if the belt is twisted and not riding in the V. If you look at yard machines web site, you should be able to find a manual listing proper belt routing.
Jul 23, 2010 | Yard Machines 155 Torque Briggs Stratton...
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Garden Logo
1,641 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
