Question about Maytag Dryers
Maytag gas dryer, model #MDG7600AWW does not turn on
I have a Maytag gas dryer, model #MDG7600AWW which is not turning on. There is a buzzing sound when you push the start button, but the motor does not kick in. I've pulled the thermal fuse, which tests as being shorted and I plan to order a replacement, but is there something else I should be checking in case there is more than one issue at play here?
  • nashuan Sep 12, 2009
    Sorry that I posted this question without realizing that the thermal fuse SHOULD BE closed to be considered "good". What else can I check to resolve this issue? I've also checked that the door switch is operating properly.
  • 736 Answers
A thermal fuse should read shorted until it gets hot .. the buzzing you hear might be the motor running but not turning the drum .. that would be a broken belt .. the motor is spring loaded to keep the belt tight ..the belt is long .. it goes around the drum and down to the motor ... belts are available at many appliance parts shops .. changing it is not hard for someone handy .. a bit more than you would want to handle if you are not mechanically inclined ... on some maytags the whole front of the dryer comes off with just two screws near the bottom .. that makes servicing much easier ..
Posted on Sep 12, 2009
  • hmlee390 Oct 08, 2009
    if the motor buzzes but does not turn then you may have a bad starter capacitor on the motor ... make sure the drum turns freely but with some resistance as it turns the motor ... that will show that the belt is ok and the motor is not frozen ...
Maytag gas dryer. Loud buzzing sound when flame comes on. Buzzing stops when gas valve off. Replaced solenoids twice. Dryer works but the buzzing is annoying. Do I need to replace gas valve assembly?
While you are hearing the buzzing, tap the gas valve (gently) to find out whether the buzzing changes. If so, the valve is the culprit.
Feb 18, 2017 | Maytag Dryers
Maytag LP Gas burner problem
are you sure the pin in the gas pressure regulator under the plastic cap and brass nut was turned 180 degrees to set it for propane gas?
Aug 20, 2012 | Maytag Dryers
Hi, i have a maytag dryer( model mdg7600aww). It works fine but every time that i use it, it smells like gas. i checked all the gas lines and found no leaks. is there something else that can cause it to...
Yes... when the ignitor gets weak and does not work right you can also get the gas smell...change the ignitor and the gas smell will go away because the ignition will be better and smoother...
heatman101
Sep 05, 2011 | Maytag MDG7600AW Gas Dryer
My Maytag dryer MDG7600AWW doesn't dry at all anymore.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 25, 2011 | Maytag MDG7600AW Gas Dryer
My Maytag dryer lites then goes back out after a few seconds. It will lite again then goes out again. Model MDG7600AWW
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 21, 2010 | Maytag MDG7600AW Gas Dryer
Dryer heats on start up and then goes away model#mdg7600aww
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
dghdhg
Jul 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
Aug 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Alantis Gas Dryer MDG7600AWW not staying hot or lit
All you need to do is replace those pesky intermittant coils
aab79a0.jpgI wote a short essay on this problem. To keep from being redundant I have it HERE
Mar 02, 2009 | Maytag Dryers
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Dryers Logo
225 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
