Question about Philips 50P8341 50" Rear Projection Television
Screen cracked the ridged screen cover is cracked need to find another one to replace..
  • 4,402 Answers
Posted on Dec 11, 2007
How to remove the outer cover of the exterior light on a 2003 Jayco Freedom pop top caravan to replace the globe
Most RV outside lights are rectangle in shape and have a plastic cover. If your light is like as described, simply squeeze the sides of the plastic cover to release the inside molded ridge on the cover from behind the stationary ridge on the light fixture and pull away.
The units are slightly different as some of them have continuous ridges (squeeze center sides) and other just ridges close to the ends (squeeze toward end of sides).
To re-install just squeeze and insert back into position.
Oct 09, 2016 | RVs
Replacement parts for northwest territory screen gazebo 9 x 13 2086km
Google the brand and model number to see if a phone number or a website exists for this equipment.
Apr 17, 2012 | Televison & Video
Depending on how bad, there are many layers of screen, if the outer layer is smooth and does not have ridges you can use a piece of Plexiglas to replace that. although glare may be more prevalent with a Plexiglas replacement. if the outer layer has ridges or more than one layer is broken there is not much you can do yourself. The screen from the manufacturer is cost prohibitive to replace. But if you have a local tv repair shop they may have a junk one, that they can sell you for a reasonable price. If it is just a small corner it might be better not to do anything at all, when you watch a tv it is the middle of the tv you watch and the corners are hardly noticeable under normal tv watching, although it may bother some people that the crack exists it actually may not cause you much discomfort watching the tv.
Oct 12, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cleaning the ridges of rear projection tv screen
Mild Ivory soap and water on a shammy cloth
do not put solution on screen put it on the cloth and the wipe
make the cloth damp not soaked
Good luck
Feb 06, 2009 | Hitachi 53UDX10B 53" Rear Projection...
A small crack in my hitachi tv screen
very espensive. new. try to find used one.  change yourself.
Dec 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cracked screen
The lenticular and fresnal screen for that unit are sold together under RCA p/n# 258513 and are available from Vance Baldwin for about $260.00 plus shipping.. They make for an oversized item so the shipping is probably 70% of the part cost.
Hope this helps!
Dec 07, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic tv model PT53WX54
You want to order the lenticular screen (has vertical ridges). The part number is TKG2AH50381 and you can find a supplier if you google it and then click on the shopping tab.
Nov 25, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
