Question about Saws
Craftsman # 315,10851 7 1/4 inch circular saw.
Craftsman # 315,10851 7 1/4 inch circular saw. HOW do I remove the blade. Cannot find an armature lock or hole for a shoft pin so blade and bellville washer spin with teh nut tite. Help? Would buy or download a manual if you have one! Thnx
Bill
  • David Ford
    David Ford May 11, 2010
    looked at a breakdown for this tool at Searspartsdirect.com and didn't see anything either. I also couldn't find a manual for you. Have you tried putting the blade against a block of wood and then removing the blade? Wish I had better answer for you but also on that site there is a toll free number that you might want to call and see if they have anything to help
I have the same saw with the same problem. lay the saw on it's side. Put a few drops of wd40 around the bolt and spring washer, after a few minutes take a old screw driver and wack the spring washer that is extending out from under the bolt head several times. Lock the blade down with vise grips or a block of wood ,the retaining bold should now brake free when you try to unscrew it.
Mike
Posted on Feb 25, 2013
  • 672 Answers
In the past I have clamped a pair of vice grips on the old blade so I could remove the bolt from the arbor.
Posted on Sep 12, 2009
How to pull out Bosch CS20 circular saw's armature?
There are several steps:
Remove the base height adjustment lever assembly(#56,57,71,72,73,74)
Remove the lower blade guard (#37)
Remove the brushes (#810)
Remove the upper guard housing (#827)
The armature will usually slide out with the upper guard - once out wiggle the armature out of the guard housing.
Reverse order to reinstall
http://www.ereplacementparts.com/bosch-cs20-0601674057-circular-saw-parts-c-128_1138_9632.html
Dec 20, 2016 | Bosch Saws
Hi, am looking for the 2 spacers and the neut that hods the blade on to a 10 inch craftsman radial arm saw and was curious if I could purchase one thank you
contact craftsman manufacturer spares to see if they are available
one washer will have a slot across the back and is the driving washer for the blade
the front washer will be flat and is the clamping washer
most manufacturers use generic products here so check for washers from other 10 " saws ( appliance repair shops , junk yard shops etc)
Sep 28, 2016 | Craftsman Radial Arm Saw W/ Stand 10 In....
Saw stopped working. changed brushes. still not working.just dead.blade turns ok.not even a click
These are notorious for burning out armatures.
The replacement process is pretty involved, I would not attempt unless you are comfortable.
Remove the brushes
Remove the 3 Screws hold the motor assy to the saw
Remove the screws holding the motor housing together.
Separate the housing and you should be able to see right away if the armature is burnt (many times the windings actually blow apart)
Often when the armature burns out it also melts the brush holder assy - I would recommend replacing it as well.
If the armature appears fine then I would lean toward the switch. Makita BSS611 18V LXT Lithium Ion 6 1 2 Circular Saw Parts
Mar 12, 2015 | Makita Bss611 18v Lithion 612" Circular...
How do you change the blade on a craftsman 10 inch radial arm saw
put a block of wood against blade to hold it then loosen the nut that holds the blade to the motor .
Sep 02, 2014 | Craftsman Radial Arm Saw W/ Stand 10 In....
Where is the blade lock for CRAFTSMAN 315.10951
quite possibly there is none . most people use a block of wood held against the blade.
Aug 16, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
I bent the depth of cut scale on a Craftsman 7-1/4 in. Circular Saw. How to true it so I can again set correct depths?
With the saw unplugged, lay it upside down on a bench or table. Put a small scrap of 2x4 against the blade and adjust until the depth of the blade matches the thickness of the 2x4. Lock it in place, Then bend or adjust the depth scale so that it reads 1-1/2 inches. Good luck.
Dec 10, 2012 | Sears Craftsman 7-1/4 in. Circular Saw...
I hava a 7 1/4 circular saw model # 5250. The blade broke off and we can't get the bolt loosened enough to replace the blade. Any ideas on how to get bolt off?
If you have no way to prevent the motor from turning when you try to remove the blade bolt, you are going to have to immobilize the armature to get it off. Remove the cap on the motor housing so you can remove or relieve the spring pressure on the brushes. Then remove the motor housing with the field, leaving the armature attached to the blade guard/transmission assembly. Now you can safely hold the armature while turning the blade bolt.
Oct 06, 2012 | Skil 5250 Circular Saws
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
Makita "7 1/4 inch" circular saw poblem. the saw seems to lose power soon into ripping boards. if you letit sit andcool, it will work again, but will quickly cease upagain. the saw blade seems to go...
Clean the armature and install new brushes, the armature is burned with carbon and loses its ability to conduct electricity properly. Make sure to in between every copper rib on the armature so it doesn't ground itself back out.
Oct 06, 2010 | Makita 5007MG 7 1/4 Inch Magnesium...
Saws Logo
340 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
