Fusing temperature control
Dear Sir,
I'm using now Dialta Minolta Di250 everytime i do 2 sided or ( back to back ) printing the machine does not work properly always stock up on the second page coz paper curl after fusing section. On the other part if i copy only 1 side copier work properly. On my observation fusing temperature is so high, please advice how to adjust fusing temperature.
Your early response is highly appreciated.
Best Regards,
Giovanni
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
1-if the paper is curling, first thing to do is try fresh new paper.
the one that is there probably has moisture.
2- is the fuser o.k. ? if the rollers are not in new condition they will curl the paper. make sure the bottom roller is shiny and smooth, it is supposed to have a clear plastic on it if it is gone or in bad shape, will give problems.
Posted on Dec 11, 2007
Co500 trouble code
C0500
Warm-up failure
- The surface temperature of the Fusing Roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle.
Jan 31, 2014 | Minolta DiALTA Di250 All-In-One Laser...
My konika minolta bizhub 162 is saying service call C0500 and then restarts what can i do
Verify the fusing unit components (heater lamp,thermistor) and the rear contact Switch located under rear cover when you closed the fusing unit right cover door.
Jan 11, 2014 | Minolta DiALTA Di250 All-In-One Laser...
How can i reset my konika minolta 162 to function well which is writing service call and a code C0500
C500 fusing unit malfunction.Look at a liitle holle on the right side on display.Press the microswitch and wait will apeire * and press 3 and press trouble reset.
I want my minolta di250/di350 to print from my computer
As long as it uses Windows 95 or at best XP. NO go with anything new it is a legacy Minolta machine. Minolta is Konica Minolta. See if you can get the drivers for Windows 95 or XP again at best.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 10, 2012 | Minolta DiALTA Di250 All-In-One Laser...
Code 0510
This is a Fuser Temperature error, You will need to have the printer serviced by a qualified technician or have the fuser unit replaced.
Aug 05, 2009 | Minolta DiALTA Di250 All-In-One Laser...
C1300 error code
· These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and communications. For remedial actions, change the board, check for cable connections, and turn the Power Switch OFF and ON. (6) C10]] to C13]] C1300 1. Reset the malfunction and turn OFF and ON the Power Switch. 2. If the same malfunction persists, check the harnesses and PJs between PH Unit and PWB-A and, if they are intact, change PH Unit or PWB-A, in that order.
Dec 27, 2008 | Minolta DiALTA Di250 All-In-One Laser...
94 people viewed this question
k24674
Marvin
Marvin
