Question about HP Deskjet 6940 InkJet Printer
Printer will not print and displays a 'black' print cartridge error message. The black ink is 2/3 full. Don't want to buy a new one and have the same problem. What can be done? Thanks
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
I keep getting a cartridge 50C cartridge error on my printer. What can I do to fix it? I can't print just anything. The test printer works but I can't print anything else.
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 07, 2010 | Dell A960 All-In-One InkJet Printer
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
color cartridge.
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
Error 50C being displayed and the Printer will not print. I have replaced both Cartridges with no joy. What should one do?
Hi there Error 50c
color cartridge.
Oct 07, 2009 | Dell A940 All-In-One InkJet Printer
Error 50c, recieving this error when trying to print or make a copy
Hi there Error 50c
It works for the 940 it may work for the 960 too.
color cartridge.
Oct 07, 2009 | Dell A960 All-In-One InkJet Printer
Cartridge error 50C
Hi there Gave it a go.
Error 50c
color cartridge.
Sep 19, 2009 | Dell A940 All-In-One InkJet Printer
Printer will not print it will say error 50c
Hi there Error 50c
Ok try this.
color cartridge.
Sep 18, 2009 | Dell A940 All-In-One InkJet Printer
Error 50c Using real Dell carts Tried reinstalling drivers still
Hi there Error 50c
Here we go try this out.
color cartridge.
Mar 26, 2009 | Dell A940 All-In-One InkJet Printer
Printer cartridge error
Hi there Error 50c
There is lots this happens with the dell printers
color cartridge.
Oct 25, 2008 | Dell A940 All-In-One InkJet Printer
DELLA 940 DOES NOT PRINT
Hi there Error 50c
color cartridge.
Jul 20, 2008 | Dell A940 All-In-One InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
131 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
