Rockola Concerto Jukebox. Model 434 The turntable does not turn after the record loading mechanism has loaded a record and stops turning. I have checked fuses, they seem to be fine.
sharcnet
  • 2130 Answers
SOURCE: stopped turning
Try removing the cover and looking for a broken belt. Make sure that the motor is spinning too. If you find a broken belt, let me know and I'll help you find a replacement.
- Jim
Posted on Jan 28, 2008
  • 92 Answers
SOURCE: Turntable does not rotate when switched 'on'.
K, I'm not familiar with that particular stereo unit but there were a lot of stereos from years gone past that used a turntable made by BSR. When you activate the switch to start the turntable listen closely to the record platter for a hum or possibly the sound of a motor turning (they're quite quiet). Is the switch lever you pull rectangular made of black plastic, you pull it towards you one click to start the record and pull it one step further (spring loaded) to make the tone arm lift from the record automatically? Just want to make sure I'm talking about the right turntable before we continue.
Posted on Oct 11, 2008
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
imend
  • 66 Answers
SOURCE: I'm using the TTYSB05 turntable for the first
There is a raise/lower button. To lower the tonearm, the button should be in the out position.
Posted on Apr 08, 2009
Grubhead
  • 5397 Answers
SOURCE: Digitech turntable - skipping stylus and arm
You might need to apply more pressure to the stylus. There should be a weight on the end of the arm, it should have a control to move it up and down. The only other thing is the stylus damaged from transit?
Posted on Feb 02, 2010
Hi I have a rockola 481 jukebox and when you turn it on a very loud deafening buzz constantly stays there ,if u play a record the overload light comes on. Dave
Can be from some mechanical parts, like small electromotors. Or from the supply power frecquency passing audio filters. Usually, changing condensers in power supply unit fix the problem.
Sep 10, 2017 | The Audio Players & Recorders
Seeburg 1960 AQ 160 Jukebox. The mechanism very hard to turn even with finger. Turntable not turning with lube added.
Rotate by hand till shaft actually receives lubricant especially if you did not remove the turntable to apply the lube 1960 model all oil dried up contaminated with dust of 57 years
Apr 25, 2017 | The Audio Players & Recorders
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
Jukebox manual
Many on eBay
http://www.ebay.com/itm/Original-Rockola-Jukebox-Model-488-Service-Manual-w-wiring-diagrams-/231244858100?pt=LH_DefaultDomain_0&hash=item35d74482f4 Original Rockola Jukebox Model 488 Service Manual wiring diagrams
Aug 05, 2014 | Collectibles Jukeboxes Book Rockola...
Rockola jukebox 484 turn table does not turn,
Drive belt for the turntable is most likely broken. Need to replace it.
May 18, 2014 | Music
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
Rockola 464 jukebox. arm that holds needle will not move over to record
The turntable will need to be removed, the pladder should be taken off with the c clip to inspect the gears, I would not be surprised if the grease has gone hard and is interfering with the cycle. Flip the turntable over to check for any restrictions. If it is a grease issue the old must be removed before applying new. Please keep me posted on your progress and if I can be of further service don't hesitate to ask.
Jan 12, 2011 | Audio Players & Recorders
I HAVE A 1951 AMI D-80 JUKEBOX,THE TURNTABLE IS JAMMED.
There are two motors with beige/tan plastic covers over them, one on turn table platter and the other on the record changer mechanism table. Take the cover off the one on the turntable and spin the motor by hand. Depending on how you spin it the arm will either go back up or down
Jan 03, 2010 | Audio Players & Recorders
Wont eject disc
Ouch!
1. power OFF
2. UNplug cord at wall
3. Turn ON jukebox (w/o power cord plugged in)
4. Turn OFF jukebox
5. Plug cord into SURGE PROCTOR (not wall, not simple power strip)
6.Turn ON jukebox.
7. If it doesn't work, try once more; otherwise ... *sigh* repair/replace..
Sep 01, 2009 | Audio Players & Recorders
266 people viewed this question
 Grubhead
Grubhead
