Question about Car Audio & Video
How do I set the clock on a eclipse cd3403 stereo radio
3 Suggested Answers
  • 4 Answers
SOURCE: setting clock on jvc radio
Hey here is an instruction page for your clock.
http://resources.jvc.com/Resources/00/01/13/LVT1775-001B.pdf
Posted on Mar 01, 2009
smartr10U
  • 1305 Answers
SOURCE: can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
Posted on May 29, 2010
Resetting clock on truck stereo
The Kenwood KDC-MP335 is an aftermarket car radio that's available for many cars and trucks. The radio unit comes with a built-in digital clock. If your clock is showing the wrong time, all you need to do is enter the radio's clock-setting mode to correct the time and set the clock.------------------------------------------------------------------------
vas 5054a v19
Nov 28, 2012 | Cars & Trucks
I had disconnected the battery on my truck. After reconnecting the battery. The eclipse avn 5435 has a screen that reads "security please insert disc". What disc? I bought this truck about a...
Eclipse radios are set up so the first cd inserted in the cd is used to unlock the radio if power is ever disconnected or the radio is stolen. You are going to have to call eclipse and see if they will unlock the radio for you. If the radio has been reported stolen, chances are they will not help you. You should be able to contact them at their website. If you can get the radio out of the dash, there is a phone number for eclipse on the chassis also.
Jul 31, 2011 | Eclipse Car Audio & Video
HOW DO I CHANGE THE TIME
    • 1
      Refer to the section of your owner's manual that addresses the car radio. Each car radio is different in the way you set the clock. If you've installed a car radio other than the one that was manufactured with the car, consult the manual for that radio.
    • 2
      Know that if this is the first time you're setting the clock or are setting the clock after installing a new battery in your car, you have to set the hour and the minute of time. Often, you set the clock with either the radio station up or down arrows. On some car stereos, you use the CD track selector buttons for setting the clock.
    • 3
      Using either the CD or radio selector buttons, set the hour first. Push the button labeled "Set" or "Clock" and then set the minute with the same procedure. When setting the minute, some manufacturers allow you to move through in increments of five by pressing and holding the button. If the time of day were 2:49 p.m., for example, you would push the button 13 times, including nine times to display :45, then four additional times incremented by one to display :49. Push the "Set" button or the "Clock" button.
    • 4
      Determine whether your car stereo is equipped to automatically change when Daylight Saving Time begins and ends. If it hasn't changed at 2 a.m. of the time-changing date, you know it isn't equipped for this. In that case, set the hour either forward or backward and the appropriate time of the year.
    • 5
      If you can't figure out how to set the clock on your car stereo, wait until noon on any given day, disconnect your car battery and reconnect it.
Read more: How to Set the Time on a Car Stereo ' eHow.com http://www.ehow.com/how_5003245_set-time-car-stereo.html#ixzz1MlfuX6eT
May 19, 2011 | Car Audio & Video
Mitsubishi Eclipse Spider Gt-S I cannot figure out how to get the fascia panel and face plate off of the radio to get to the numbers needed to retrieve the radio code. How do I take the panels OFF?
Hi
The stereo in the Eclipse can be removed with nothing more than a Phillips screwdriver
Disconnect the negative battery cable from your Eclipse's battery. Remove the two Phillips screws along the bottom of the radio/climate control trim panel. Lift up the bottom of the trim panel to unlock the lower retaining clips. Work your fingers around the sides of the panel to loosen the other clips and remove the panel. Remove the four Phillips screws holding the stereo in place. Slide the stereo out of the dashboard and disconnect the wiring harness and antenna cable from the back of the device.
Also check this link if it helps:-
http://www.ehow.com/how_5938157_remove-eclipse-car-radio.html
May 04, 2011 | Mitsubishi Car Audio & Video
Set clock on radio
Try the following website for the instruction on how to set the clock radio.
http://www.eclipse-web.com/us/manuals/manuals.html
Aug 17, 2010 | Eclipse CD2000 CD Player
How do you set the time for an eclipse 3309 cmt
to set the clock on a eclipse e3309cmt stereo :
press and hold the "clock/display" button, then number 1 or 2 for the hours 1 = up 2= down.
the 3 or 4 for the minutes 3=up 4=down.
Jun 17, 2009 | Car Audio & Video
Setting the clock
For finding Radio user manuals - it is best to exhaust the manufacturer's resources before downloading a file from a potentially harmful site. Click the following Brands to navigate directly to their SUPPORT page to look up the model number of the radio you are looking for. Alpine
Kenwood
Sony
JVC
Pioneer
Eclipse
Panasonic www.RETREVO.com and www.DiploDocs.com are also great resources to find the oddball or older model guides. If you are looking for an installation guide, the industy-wide color chart can be found by CLICKING HERE.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 09, 2009 | Alpine CDE-9846 CD/MP3 Car Stereo
How can i find the fuse for my clock and stereo display?
had the same problem with my 03 eclipse. check your cigarette lighter fuse. powered on the same circuit. that was my issue
Mar 13, 2009 | 2003 Mitsubishi Eclipse Coupe
How do I wire an car stereo to an equalizer
from what you have explain you have a no experience to do so get your system installed by an audio installer safety come first and u have no clue for your safety seek a qualified person to do it
Mar 13, 2009 | Car Audio & Video
Display mode is flashing
if it is anythang like the 2002 eclipse gt stereo there is 2 button on the right side of the display screen hold the right one down and it will change the mins and the other 1 will change the hours
Nov 16, 2008 | 2002 Mitsubishi Eclipse
Car Audio & Video Logo
309 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
