Question about Fisher and Paykel GWL11 Top Load Washer
Hello again MNfisherman, To be able to narrow this problem down on my F&P Washing Machine you have suggested to me that the problem could be a switch. Can you give me an idea where this switch is located, is it the tiny switch on the circuit board itself or is the switch located elsewhere?
  • Sonia Fordham
    Sonia Fordham Sep 12, 2009
    No. The problem is a F&P Kelvinator 508 5.5 Washing Machine which is now getting on in age. My problem is the START/PAUSE button. Have checked all other parts of the machine, circuit board, water valves etc.etc. One of the sensors at the front of the machine under the lid has perished which is made of soft plastic, so when I have the two taps turned on & the washing loaded & set the cycle for a wash then press the start/pause. it beeps but nothing else happens, in other words the machine does not start. Or could this be the main motor problem or as suggested a switch problem. I need to narrow this down to just one of these three things.
  • Sonia Fordham
    Picked up on a different problem!
  • 986 Answers
Fault: Water starts to fill then stops, waits a few seconds then tries to fill again then stops. repeats the cycle a few times then beeps with error lights.
Solution: The problem was a faulty balance switch. (Located under the main controller - below the control panel). It tested >5 ohms closed and had water marks.
I hope this is the issue you are having as the previous problem was not posted
Posted on Sep 12, 2009
  • Roger Campbell
    Roger Campbell Sep 12, 2009
    Its the switch under the lid.
Fisher&paykel ,smart drive excellence 7 .5 ,the washing machine stopped working during the pumping out of the water.no power on the top panel and a slight humming noise
What is it? No power to panel or slight humming sound which indicated there is power? Can't be both. I would suggest that the humming sound if you put it on spin, will be the drain pump trying to go. If pump is left humming like that it will get hot & shut the power off until it cools down again. Pump hums when it has a blockage & can'y spin. Clear the blockage.
Dec 29, 2016 | Fisher and Paykel Washing Machines
Machine stopped working during use.
Hello! There is a trouble shooting guide for major appliances that frequently suggest parts and video links on youtube that diagnose your problem & instruct you how to repair your appliance. The site is called Repairclinic.com. Make sure you have the model number before you begin since the instructions are model specific. Good luck.
Jun 21, 2015 | Candy CNW136 Front Load Washer/Dryer
Hotpoint washing machine faults
Nicky, try a dry run without a load. Also check if moving to different levels gives you any reading. If not, you have narrowed down where the problem is.
Mar 01, 2014 | Washing Machines
The bobbin carrier brakes off a piece at the screw area, I hav bough two and it brakes off again and AGAIN .
I would suggest taking the machine to a sewing machine shop & asking them why it keeps breaking
Mar 13, 2012 | Singer Confidence 7467 Mechanical Sewing...
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
I have a fridgdaire front loading washing machine and the code e70 keeps coming up and the whole system will shut down what does this mean???
You are going to need to download the Factory Service Manual for your Washer. This is a General Code, not specific to anything, You need to run the machine through it's diagnostics to determine the service code that is stored.
Once you get the service code you can narrow down and identify the issue.
Here is the Repair Manual Download Link
Thanks
Jan 06, 2009 | Frigidaire ATF6000ES Front Load Washer
MAchine does not agitate
taped to the inside front panel should be a techsheet/ trouble shooter with a pretty detailed walk through, of all component cks, pretty complicated machine , the diagnostices narrow it down a bit
Mar 05, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Wi 101 INDEST
you might have a pressure switch problem due to a blockage in the sump , but more likely the fault is down to tracking on your control board. You might be lucky and find that if you take the board out and clean it around the the botttom of the printed side it might just work, failing that I suggest you call an engineer
Aug 01, 2007 | Indesit WA 115 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
93 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
