Cable length has nothing to do with it. It may even be on the computer side as corrupt driver installation etc. Make sure the cable connections are correct. uninstall the device from the device manager and reinstall.
That's one of the problems I even have in my own home, one printer will load fins and another 2 feet away will not. This may come down to being a hardware failure within the printer itself. Do you have another pc, like a laptop that you can load the software on to see if another device can take over operations of the printer?
local authorized service center in your area for additional assistance.
Replace scanner control card (SCC) first, if no fix replace FB CCD Asm
Parts number
40X2194 - SCANNER CONTROL CARD
40X2193 - FLATBED CCD ASM
No: If the 900.80 error does not appear on the printer screen, use the printer operator panel
to print a menu settings page. If the error does not return, continue using the printer.
If the installation screen does not appear:
In Windows 2000, double-click My Computer from your desktop.
It's still not working although I have uninstalled and reinstalled it. I even tried using LPT connection i/o USB.
When I installed it there was a warning saying it won't work properly. Could it be because of my Window XP compatibility?
But if it is the case how could I had no problem when installing my Xerox XE80?
