Question about BenQ PB6240 Multimedia Projector
What should be done if the temperature indicator light comes on
  • 2,237 Answers
Clean out the dust in the projector with canned air, make sure the fans work, and keep an open space around it.
Posted on Nov 12, 2009
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
The heater light light comes on when first low circulation cycle is pressed but turn off when you press again but only for 20 minutes
It is supposed to. When the heater reaches the temperature you set, it goes off and the indicator light goes off too telling you the heater is off. Soon the temperature drops again and the heater, and the indicator light, comes back on.----This is the working procedure.------ The pressure switch, float switch all needs to be inspected.------- Also what is the exact brand and model of your heater.This will help, to get exact cause of the problem. --------- Keep updated, thanks.Helpmech.
Aug 13, 2011 | Pool & Spa
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
Onece the range selector is turned on the light comes on but soon goes out, if you move the selector a little the light comes back on, this stove was made around 1952. Thank You, Dave
Are you talking about the oven temperature control? When turned on to the selected temperature the oven indicator will light and the element will work. When the oven reaches the desired temperature the power will shut off to the element and the indicator light will go out. When the oven cools slightly the indicator light and the element will again turn on. When it does turn off and you turn the knob slightly to increase the temperature the indicator light and element will come on again as you are asking it to heat to a higher temperature. This is normal oven operation.
Mar 10, 2011 | Kitchen Ranges
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Check engine light, and engine temp gauge drops. Otherwise car is running well.
If the thermostat is stuck open, the engine temperature will drop and set a fault code indicating that the engine is not reaching operating temperature. This will cause your check engine light to come on. Have someone scan your engine computer. Most large parts chains will scan for codes at no cost to you. If there is a "Thermostat" or "Engine temp low in closed loop" or a similar code indicating low engine temperature, replace the thermostat.
Dec 04, 2010 | 2004 Mercury Grand Marquis
1997 Chevy Malibu cooling fans problem
I don't have the solution but I have the same problem. You are not alone. I have done everything you have done and have run out of options as far as fixing it with OEM parts. I am going to over ride the system with a hot wire and toggle switch and tie into the led wire on the #1 fan so when temp starts to rise past 180 degrees I can turn the fans on. Freeway driving is ok for me, no fan needed, just when I get off the freeway and around town engine gets hot. My toggle switch has a L.E.D. light in it to indicate the switch is on.
May 08, 2010 | 1997 Chevrolet Malibu
My temperature gauge warning light is coming on periodically...oil level is fine. What should the temperature be at? Is it possibly a sensor problem?
The temperature guage measures the coolant temperature, not the oil temperature -- the normal range is indicated on the guage.
Check your coolant.
May 06, 2009 | 2001 Audi A4
BenQ PB6240 Multimedia Projector Logo
156 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
