Question about Sony VRD-VC10 DVD±RW Dual Layer Burner
Sony vrd-vc10 drive door
The door of the drive will open, sounds like it is trying to but won't unlock
    Scholar:
  • 102 Answers
Davidxjohn
Right on the drive you will find a small hole, take a pin and press it a little bit, it will open up the DVD tray for you. Sometimes the drives are just locked by some software, this is the best way to release your stuck cd or dvd.
Hope that helped!
Posted on Dec 11, 2007
  • Gary Casselman Apr 19, 2013
    Drive does not open even when paper clip pushed into small hole.
    Drive door did not open with paper clip pushed through hole on my MC5.
Door will not open
Straighten a paper clip, locate the little hole in the drive door, insert the paper clip and give a little push on it. This is a release button in the event you can't power up a computer. If it still does not open you will probably need to replace it, getting it repaired will be just as much if not more probably.
Sep 21, 2010 | Sony VRD-VC10 DVD±RW Dual Layer...
No Disc inserted or drive not ready, please try again
can u do firmware update i have nero 7 for u i f u want it do u have yahooo
Jan 29, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
Needs driver for vista or win 7 Sony VRD-VC10 DVD±RW Dual Layer Burner
Sony does not support this burner for any operating system for Win2k and XP. The VRD-VC30 is supported in Win7 but no earlier models (from the Microsoft Compatibility Center). The Vista Compatibility Center lists the VRD-VC20 as unknown for Vista support.
There are work-arounds. Install XP as a virtual computer or in a dual boot configuration on your system and install the hardware on the "XP box". If you have Win7 Pro or Ultimate, you can download and install the XP mode for a free virtual computer. (This requires you to download two programs from Microsoft and install them (Virtual PC and the XP mode itself). Otherwise, you will need a valid XP license to install in the virtual computer software. The dual boot may work better for you since virtual computers can't share files from the main computer directly. They need to be transfered to external media or a different partition or disc that unmounted from the real computer and mounted on the virtual computer.
I hope this helps.
Jun 25, 2010 | Sony VRD-VC10 DVD±RW Dual Layer...
I need to replace the USB 2.0 connector on a Sony VRD-VC10. How do I remove the case?
hi
Do you want to do it yourself or do you want a pro to do it
Where do you live?
regards
tekspotCoUK
Sep 08, 2009 | Sony VRD-VC10 DVD±RW Dual Layer...
Own a sony dvd recordable drive (VRD-VC10but for some reason the blank disc reads ''NO DISC''.
something wrong with the processing unit on you drive causing it not to communicate with the pc. best bet is to replace it with a new drive.
Aug 29, 2009 | Sony VRD-VC10 DVD±RW Dual Layer...
Sony VRD-VC10 Not Detected
You can try the steps below.
Edit the registry:-
1. Click Start, and click Run.
2. Type regedit in the Open box, and click OK.
3. In Registry Editor, click the plus (+) sign next to each folder name to expand the following registry path:
4. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
5. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. In the right pane, right-click Upper Filters, and click Delete.
7. Click yes when prompted to delete the registry value.
8. In the right pane, right-click Lower Filters, and click Delete.
9. Click yes again.
10.Close the window and restart the computer
Please do not forget to rate the solution.
Regards,
Musheer.
Aug 11, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
VRD-VC10 says "format mismatch"
Check the manual - some DVD recorders could only handle certain brands of disks, and most will not handle Dual Layer types. Try Sony brand DVD-R disks (4.7G)
Jul 25, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
Sony dvd vrd-vc10
try downloading from this site www.slysoft.com thier systems is 100% wonderful for reading writeing and rewriteing cd's dvd everything and you can even test drive it for 20 days before you have to buy it,and I have herd nothing but good from eveyone i have sent there lala linda
Jun 02, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
Setup Nero for CD recording mode, not DVD. The software does not change automatically.
Dec 09, 2007 | Sony VRD-VC10 DVD±RW Dual Layer...
Problems
You have a jammed disk - that sometimes happens, and requires that the case be opened, and the disk manually removed.
Sep 22, 2007 | Sony VRD-VC10 DVD±RW Dual Layer...
Sony VRD-VC10 DVD±RW Dual Layer Burner Logo
179 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
