Question about GE JVM1350BW/WW/AW/SY Microwave Oven
Flashing is occurring around the plastic turntable piece which is causing it to melt. Took off and saw that the enamel was pitted around the turntable opening. When I remove the plastic turntable piece, no flashing occurs and seems to be fine (this was all after removing the turntable motor BTW which itself seems fine. No scorching, etc.. on it at all.) Put the plastic piece back over hole, flashing/burning again occurs. Is it the pitted enamel causing the problem?
    Scholar:
  • 178 Answers
It sounds like you are talking about the turntable tray adapter in the bottom.
What usually causes arcing is the reaction of the RF (microwave) energy acting on carbon. It's great that the motor and orifice are OK. Sounds like you just need to replace the T/T adapter. If the paint is pitted or altered, you need to use a special catalytic paint for microwave cavities to touch it up. The paint's main purpose is to protect the metal from rust but it is a high temperature paint to stand up to the higher temperature of that environment.
Posted on Sep 13, 2009
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
Melted plastic turntable teeth
If only the teeth, get a new replacement ring . If it has melted so bad that it is part of the m/wave floor, you don't have much choice. Have you tried speaking to manufacturer?
Aug 07, 2013 | Samsung Microwave Ovens
It burns thru the glass trray and melts the wheeled tray holder...
There are two possible reasons for this to occur.
1.there was dirt on the turntable and that carbonized and got so hot that it melted the tray. That heat would've melted the plastic spider as well.
2.the microwave oven was turned on with nothing. or almost nothing, in it: the glass turntable is what is known as "a matching load". That means it is there as a safety precaution, protecting the magnetron, in case there's nothing in the microwave oven when it is energized. As such, the glass turntable can get hot enough to melt. That, in turn, will melt the plastic spider.
If either of those is the case, it is OK to buy a new spider & turntable.
Mar 10, 2011 | Microwave Ovens
Maytag Over The Range Microwave: Melted glass turntable, rollers
Considering the melting pooint of glass ...
Normally, microwave travels around round surfaces (Look at the B-1 for example) If you put flat metal in a microwave, you will create sparks ... lots of em. Is it possible you have something going on with one of the wheels ... like a piece of tin foil?
At a minimum, I think id be inspecting everything inside very carefully and then give it a good cleaning.
You might want a pro in your area tale a look at this as well.
a
Oct 05, 2009 | Maytag MMV4205 Microwave Oven
Can I paint rust spots w/enamel paint? Dangerous to use?
You will need to buy a appliance high heat paint. the spray can works the best.
May 03, 2009 | Microwave Ovens
Plastic piece for turning turntable has partial meleted.
This is a pretty simple, inexpensive fix,
The best place to order parts for this brand is Encompass (formerly Tritronics).
If you don't find the part on their Web site, I would call them with your model number. They are toll-free at 866-779-5835.
Feb 02, 2009 | Goldstar MV-1715 1000 Watts Microwave Oven
Metal turntable's enamel chipped, so sparks fly.
Try Going To Your Local Hardware Store And Finding Enamel Repair.
It May Just Cook But I Hope It Doesn't.
Jan 05, 2009 | Sharp R-820B Convection/Microwave Oven
Need to find turntable mount for Emerson MW8117W Microwave
Go to repairclinic.com and type in your model number. I suspect you may be talking about item 1063610, Turntable Coupler. You may also try searspartsdirect.com. If this isn't the part you need, please post back and provide more information, so that I may assist you better. I hope this helps.
Jan 04, 2009 | Emerson Black Microwave Oven
GE JVM1350BW/WW/AW/SY Microwave Oven Logo
196 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
