Question about Moen & One Handle Tub & Shower Faucet
Cant remove the knob off the one handle 1960's moen
  • 129 Answers
You will need a handle puller, you can get one at a hardware store. You might even try pouring alittle vinegar on it first, toloosen it up. Be gentel and try pullers first, then try to wiggle maybe. Being so old the end of stem might break off in handle. If so remove stem and take both handle and stem store to match up. P.S. remember to shut off water at main first.
Posted on Sep 28, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Replace handle with different style
    One of those big-box home suppliers might have something you can use or can order something. Likewise, a plumbing supplier could have just what you are looking for. Moen is a common brand which makes compatibility more likely
    Feb 09, 2013 | Moen T999P Chateau Two-Handle Low Arc...
    My single moen posi temp shower knob wil not completely turn off my water. In the closed position it still runs a slow stream of water.
    Remove the handle and see if it will turn off without the handle and if it will reposition the handle alignment and your good to go. If no the cartridge will need to be replaced.
    Feb 12, 2011 | Moen & Posi-Temp Single Handle Shower Or...
    I have a Moen shower knob that broke...
    You are not the first. Usually you must break the plastic handle to remove it and then you can access the screw and have leverage to hold the brass stem with pliers while you try removing the screw. Caution, do not try to bend the handle to break it off or you will break the brass facet stem. Also, there are two styles of handles: one has a short innercone,the other has a longer inner cone. You need to know this before you purchase a replacement. Goodluck< Macgivor
    Dec 27, 2009 | Moen & One Handle Tub & Shower Faucet
    I have a moen fawcett. single knob, it is leaking
    the spout is the end piece where the water comes out. where is it leaking ?.
    when you put it back together i would suggest you use some teflon tape often called plumbers tape on all the theaded fittings as that will prevent any leaks as well.
    Nov 27, 2009 | Moen & One Handle Tub & Shower Faucet
    Leaking shower head
    Check the spout pull knob . Debris can be keeping it from closing completely.
    Jul 05, 2009 | Moen & One Handle Tub & Shower Faucet
    Compatible replacement handles for Moen Garden Tub faucet
    I dont know if moen made chrome handles for that valve back then. If they did then they will probably be lever handles but they wont turn correctly unless you remove the cartridges and turn them. Iwould suggest probably replacing the whole unit.
    Apr 20, 2009 | Moen Chateau, Two-Handle Garden Tub Faucet...
    Moen & One Handle Tub & Shower Faucet  Logo
    439 people viewed this question
    Top Moen Home Experts
    Mike
    john h
    Andrew Bugbee
    Are you a Moen Home Expert? Answer questions, earn points and help others
