Question about Xerox WorkCentre M20i All-In-One Laser Printer
The copier doesn't copy and appears this on the screen "paper size mismatch" when you hit copy
PABLOCSA
  • 1124 Answers
SOURCE: I am trying to print
Check your printer preferences. Check inside the printer if it has some paper jam.
Cancel all your printer jobs, turn off the printer - Turn on the printer and try again
Posted on Oct 08, 2008
jonb3838
  • 237 Answers
The tray itself should have tabs on the side telling the type of paper look at those and see if there is anything broken off.
Posted on Feb 11, 2009
SOURCE: cannot print envelope on HP Photomart C6180 All in One
What program are you using? If it's Microsoft Word, are you using the Mailings section, and envelopes?
Posted on Apr 19, 2009
SOURCE: Paper Mismatch
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
Posted on May 04, 2009
  • 2072 Answers
SOURCE: paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Posted on Nov 05, 2009
Aligning Paper
This sounds to me like the paper inside the tray is a different size than the printer properties is configured to expect as default. To see whether this is the case, right-click on your printer and go to Properties (Printer Properties if you are using Windows 7), then select Preferences... On the next window that appears, click on the Paper tab and look at the Original Size that is selected. Presuming that you have Letter paper in the tray, select the Original Size as Letter and click OK.
Jul 13, 2014 | HP LaserJet 4 plus Printer
How do i print on cardboard (heavy paper card)
The mx2300n only supports up to 209gsm heavy card. You must make sure that your heavy card is not over this rating.
Set the bypass tray as 'Heavy' by clicking on the trays on the main copy mode screen, select type & size for bypass. Select heavy, and Auto AB as this will allow the tray guides to detect the size of your paper. Load the tray with up to 20 sheets of Heavy paper.
Open your document, select Print, then properties. Under the 'paper' tab, select paper source as bypass tray, and paper type as heavy (if you miss one of these steps, the ,machine will ask to load paper due to size or type mismatch).
That's pretty much it.
Oct 16, 2013 | Sharp MX-2300N Color Copier
When copied the copy comes out half of page not copied
If you state your copier model more accurate help will be possible. In general it seems there is a mismatch of the sizes of original and copy paper.
Apr 21, 2011 | Sharp Office Equipment & Supplies
When I try to line tells me that the paper size mismatch and only takes a copy of the text
Have/had the same problem: Getting "paper size mismatch" on the C4280 status screen, after we got a paper jam. Every time we hit OK and put in paper, Message about "Now printing Alignment page", it feeds through quickly, with nothing printed on the page and reverts back to Paper size mismatch. Finally got rid of the error, not sure how, but now when I try to copy anything, we only get the lower right postion of the document that I'm trying to copy. Printing from the PC seems ok.
Powered off and back on, and it is back to P"now printing alignment page, quick feed through and "paper size mismatch" error. AND
When copying directly from the glass panel,it will only print a quarter of the page -however it prints and coorectly if we print directly from the computer.
The problem is the paper size sensors. Remove the plastic access panel that is for access to the rollers in the back and has 4 rollers on it. There are two papaer sensors attached to the printer circuit board (PCB). The control arm for the sensor is a small plastic piece that extends slightly into the paper path above the PCB. The plastic can be broken when you are removing a paper jam. I stuck a small piece of a match stick in the sensor to keep it open (as though a wider piece of paper was passing throught the printer). I can't switch to smaller card stock, etc, but who cares, it works.
The copying problem is caused because the C4280 will not scan correctly until after it does the alignment phase.
Dec 16, 2010 | HP PhotoSmart C4280 Laser Printer
Paper size mismatch is appearing on the screen
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Get paper mismatch error.doesn't happen if I just copy,but has started giving paper mismatch everytime I try to copy from computer. I have tried everything suggested in tutorials. It doesn't copy if I just...
Clean the sensor on the right side bottom of the carriage assembly with a damp Q-tip. That sensor gets covered with ink and can't see the paper properly. You clean the underside that looks down at the paper as it passes thru...
Jul 21, 2009 | HP Photosmart C5580 All-In-One InkJet...
Paper mismatch error
I got around this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 25, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper size mismatch
If the paper supply trays have movable edge guides, make sure the guides are against the paper, also insure the paper is oriented the same a s the print job or copy require.
Hope this is of some help.
Ed
May 06, 2009 | Xerox WorkCentre M20 Black and White...
I am trying to print a copy and I keep getting message.... Paper mismatch. Try changing the paper type/size or paper in tray. I am using the same 8.5x11 paper I have always used. Reference guide does not...
Oct 08, 2008 | Konica Minolta magicolor 2300DL Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
56 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
