Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Refrig is frezzing
GE Model # PSS25NGMD. Refrigrator is droping down below frezzing. Can't get to stay above freezing. I think it is the thermostaic. Not sure where its located.
  • tomaszewski Sep 13, 2009
    I examine the inside of the back of the freezer behind the rear panel and the side of the coil there was frost and ice build up. How do I tell if the door from was not working properly?
    Thannks, Dave
  • Anonymous Mar 24, 2014
    sometimes it is ok, most of the time all veg. freeze
  • GE Master
  • 4,654 Answers
Your model a WR49X10091 Electric Controled Air Damper between the freezer and the fresh food section. Sometimes they get stuck open and sometimes the electric motor malfunctions. Most times a little frost will hang them up. Until we can see that we can get this part opening and closing properly we will need to unplug your refrigerator and examine the inside of the back of the freezer behind the rear panel to see if there happens to be frost stopping the door from regulating temperatures. I will be here waiting for your comments and results. Let me know what you find, Thanks, Sea Breeze
Posted on Sep 12, 2009
My ps3 frezzes after a few seconds of being on. WHat happend?
Hello
your PS3 is freezing simply because your console is affected by heat, so you have to cool it down.
If the freezing continues even after cooling down, you can follow the steps below:
To stop the PS3 from Freezing, you could begin by putting off your console and wait for 20 minutes. After that, put it back on.
Check if there's any loose cables. If there is, put them back in.
If the freezing continues after taking the above step, you can follow the link below as a guide on how to fix the problem.
http://www.squidoo.com/PS3-Repair-Guide
Good luck.
Mar 24, 2010 | Sony Playstation 3 (PS3) Console
I have a GE Profile Artica S/S, model # PSS25NGMD BB. The fridge side is freezing the food and the digital thermometer keeps going back to 22-25 degrees. Also, yesterday the in-door water dispenser quit...
With temperatures like that the water tank is frozen stopping water to dispenser. This could be thermistors in fresh food section going bad or a combination of thermistors and motherboard. I can assist you if you have not already called for a technician. Sea Breeze
Mar 23, 2010 | GE Refrigerators
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
Our GE monogram refrig compartment is constantly below freezing.
2 possibilties most likely is a bad temp sensor it thinks its warmer in the refrig than it actually is. the next possibilty is a motherboard has gone bad in the unit.
Jan 21, 2009 | GE GSS20IEP Side by Side Refrigerator
GSH22SGR GE Refrig
Do you check the switch located into the freezer?. it will be On
Nov 20, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Ge rifrig will not defrost
you have a defrost issue not being able to verify circuits on the mother board i would replace the high limit, what you are calling the termination stat this stat stays closed unless the temp hits 140, thats right 140 degrees f and change the evaperator sensor.
evap sensor can cause missed defrosts or no defrosts
high limit part number wr50x10068
sensor number is wr55x10025
each part is 7-15 dollars each
Apr 07, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
207 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
