Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Is there a way to bypass ul code sensor on a cabrio wtw6400sw1
  • fschill Sep 12, 2009
    being this is a sensor must be a way to bypass sensor.at first thought it was rotor replaced that.then thought it was supports took all out cleaned regreased.still when it gets to spin cycle even when empty gives ul code.cannot by parts at this time need to make work
  • 986 Answers
HI,. this codesis there a way to - 2.gif represents a control board fault. you will need to replace the Machine and motor control board.
This board is a all in one unit. it controls the basic logic points and the motor as well. It is damaged.
Posted on Sep 12, 2009
    Brigadier General:
  • 8,619 Answers
Hi
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing you to view and redistribute the load.
Unfortunately, there is no other way to bypass ul code.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
My Whirlpool Cabrio Washing machine has the code UL. I know that means unblanced load but it is not rinsing and spinning on everyone of the loads. How do I fix this problem? I have had this machin
You should Always check the pump and filter first before anything else is checked. They have automatic cut off if it senses a blockage in the electronics of the pump.
Jan 08, 2015 | Whirlpool WTW6400SW Cabrio Washer
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a cabrio washer WTW6400sw1 getting F1 code. what do i do to fix it.
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
Aug 14, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I receive a UL code on my Cabrio and it the clothes are very wet after spin cycle...
The ul error code means unbalanced load.If the load in the drier is much more than it can take, the system will not perform its operation. I can suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on washing machines and other appliances. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad.
thanks for rating good luck
Feb 04, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool washing machine with the load sensor doesn't put enough water in to cover the clothes. Can this be adjusted?
The water level cannot be adjusted, but sometimes the pressure hose gets obstructed. Remove the three screws from rear of top panel to gain access to the main control. The pressure hose is attached on the RH side of it. Remove hose and blow through it to assure clear air path. If problem remains, replace control. Control available HERE, and using coupon code 1050 will get you a discount on the part!
Jan 12, 2011 | Whirlpool WTW6400SW Cabrio Washer
Cabrio washer with uL code. Will not operate properly after resetting & not even with small load.
if it went thru the mini-cycle to redistribute the lad of clothes and it continues to flash uL then open the lid and manually redistribute the load,if this doesn't correct the problem,then try unplugging the unit for 15 minutes to re-set the ecu control unit and re-plug in and retry it
Nov 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I HAVE A WHIRLPOOL TOP LOAD CABRIO WASHER MOD. #WTW6400SW1 I AM GETTING A F1 CODE SOME TIME AT WASH CYCLE SOMETIME ON RINSE CYCLE WHAT ISTHE PROPLEM
Hello
Error code F1 is caused when the control on your washer is either bad or about to go bad. This is a common issue with Whirlpool Cabrio washers and they are aware of this. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge you for the part. Please get back to me if you have any other questions.
Kevin
Nov 14, 2010 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The time display section indicated a code UL instead of the time left on the washing cycle. What does this code mean
keep getting a ul code and machine barrel knocks back and forth in the washer on spin cycle until the ul comes up. Cannot get it to quit. What is the problem?
Thanks
Aug 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
247 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
