ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard
Problem for ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard
Motherboard has a long beep after initialization
By kemosave on Dec 11, 2007
hello.i'm just having a problem with my motherboard ASUS CUV4X-C it is a pentium III board.the problem is.after boot initialization the mainboard has a long beep just like keyboard stuck.I changed the keyboard but same problem that it gave.what is the problem of this? can you help what will I do with this.this my frist encountered problem.I changed the BIOS chips but the same problem.thanks for helping me..
Comments:
Dec 11, 2007
- i tried to change RAM modules..I will try to remove those capacitor.thanks for helping me..
Solution #1
posted on Dec 11, 2007
Somewhat Helpful)
Chandrasing
Rank: Apprentice
Rating: 70%, 1 votes
Did you try with different RAM module? If yes and still having the problem then its the keyboard connector which is having problem. Most of the time the capacitors next to the connector, which are meant to subside the external noise, do not function properly. If you have soldering iron, just get rid of those capacitors and you are good to go. If all fails then south bridge has problem which can not fixed easily(in most cases it can't be fixed). Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for ASUS VIA Apollo Pro133A
Questions and Unsolved Problems for ASUS VIA Apollo Pro133A
Do you recommend ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard?
Answer
Answer
any sound or animation on any web site causes computer shut off and restart.h.d. replaced 4 shops... (More)
Answer
Mobo Samsung Harappa-12 can I have a manual pls? pdf or something my email add is... (More)
Answer
I don't know which poles to put the wires on from the power switch to my ices 003 b motherboard
Answer
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the... (More)
Answer
how do i unlock channels on an ntl set top box?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
