Question about HP Officejet Pro L7780 All-In-One InkJet Printer
When Scanning Digital Imager is not seen
My scanner worked to do PDF. Then one day it stopped, I could only use MS Scanner and Camera Wizard to Jpg. HP help me download the software and it worked for awhile. It stopped again and no matter how much uninstalling and reinstalling I cannot get this working. If I install with the disk I can see the HP Solutions Center but HP Express is gone. If I install the download the HP Solutions Center is gone so I cannot set it up to do PDF scanning.
Trouble scanning a document as a .pdf file
You need to have a pdf-handling application installed on your computer. At least you should have Acrobat Reader. There are several pdf handling applications on the web. Google pdf. (pdf Architect, pdfTK, pdfBulider etc.)
Jan 09, 2014 | Canon CanoScan 8600F Flatbed Scanner
How to scan multiple pages in one pdf in hp 5300c scanner
To do this will take a few steps.
1. You need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
2. Scan the first page then click on File - Save the image as a jpg file Eg. image1.jpg
4. Repeat step 3 for the other pages.
5. Close the scanner when finished scanning.
6. Open a Word document then place each image file on a new page in the Word document
7. Save the Word document (not necessary).
8. Click on File - Print then select CutePDF printer (or your PDF printer driver) and save the PDF file. This PDF file will contain the multiple pages of the scanned pages.
Jul 07, 2011 | HP ScanJet 5300C Flatbed Scanner
Scanning document in PDF format
To scan in PDF, you must have a PDF scanner please download and install a program like scantoPDF or others that you can use, like, NitroPDF, or Adode Professional, Either that or you can simply convert the JPG, to a PDF, with a printer, a virtual printer that "Prints" PDF, as PDF is a printing format, and it is done in software. So there is Print2PDF, PDFPro, and many others that will scan and print also you can get a PDF plugin for MS WORD as well.
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=scan+to+PDF
above is your link for scan to PDF & Below is the Print to PDF.
http://www.google.co.nz/search?num=100&hl=en&q=print+PDF&aq=f&aqi=g-c1g1g-c8&aql=&oq=&gs_rfai=
May 24, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How do i setup the scanning part?
hiii
You can perform following step:=====
1.Insert the document you want to scan into your scanner.
2.Click Start, click All Programs, click Accessories, and then click Scanner and Camera Wizard
3.The Scanner and Camera Wizard appears. Click Next.
4.In the Choose Scanning Preferences page, click the Picture type option that best matches the paper you are scanning, and then click Next
5.In the Picture Name and Destination page, type a name for your image, select JPG as the file format, and select the folder where you would like the scanned image to be saved. Click Next.
6.Windows XP scans your document. On the Other Options page, click Nothing. Then, click Next.
7.On the Completing the Scanner and Camera Wizard page, you can view your scanned document by clicking the link shown. If you are not satisfied with the results, click Back to return to the Choose Scanning Preferences page, adjust your settings, and try your scan again. Repeat until you are satisfied. Click Finish to close the wizard and open the folder containing your scanned document.
Jul 28, 2009 | HP Officejet 4315v All-In-One InkJet...
HP 1410v all-in-one scanner won't work
Please follow the steps given below to scan from other applications.
Windows XP:
Scanning from Microsoft Paint:
1. Click Start, click All Programs, click Accessories,
and then click Paint.
2. Click File and then click From Scanner or Camera.
If this option is not available, Please let me know.
3. If more than one image source is connected, select the
HP all-in-one product and click Next. The scanning software
will appear. Preview the image by selecting Preview,
or click "Scan" to scan the image directly into Paint.
4. The image will open in paint for editing and/or saving.
Using Windows Image Acquisition (WIA)
Verify that the all-in-one product power is turned on and the printer cable is properly connected.
1. Click Start.
2. Click Control panel.
3. Click Scanner and Camera Wizard.
Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If it is possible to scan from any of the above methods, try to scan from HP schortcut File and get back to me with the results.
Scan Shortcut:
1. Search for the file hpqscnvw.exe
2. File should be available in the following location
C:/Program files/HP/Digital Imaging/Bin folder
3. Create a shortcut on the desktop and double click the same
to activate the scanner and try scanning.
Windows Vista:
Scanning with Windows Photo Gallery
1. Click the Start ( ) icon.
2. Click All Programs
3. Click Windows Photo Gallery
4. Click File and then click Import From Scanner or Camera
5. Click Import
6. Click Scan
Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate,
Windows Vista Business, and Windows Vista Enterprise.
1. Click the Start () icon.
2. Click All Programs.
3. Click Windows Fax and Scanning.
4. Click New Scan.
5. Click File and then click Scan.
Scanning with Paint
1. Click Windows.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Scanning from Shortcut File
* Click on the Windows logo to access the start menu.
* Click on Computer.
* Double click on C:\drive icon.
* Double click on Program Files folder.
* Double click on Hewlett Packard or HP folder.
* Double click on Digital Imaging folder.
* Double click on the bin folder.
* Locate the hpqscnvw.exe file and double click on it.
Vishwanath V U
May 19, 2009 | HP PSC 1410v All-in-One Printer
Can't get scanner to work
Try oprning up Windows Photo Gallery, then File tab at top, then click on Import from Scanner or Camera.
The HP should come up as an option, so click on it.
I found that with upgrade to Vista, the actual SCAN button on the HP 2210 did not work -- but this back door through Photo Gallery lets me scan and import the scan as a jpg file.
VLW
Feb 21, 2009 | HP PSC 2210 All-In-One InkJet Printer
Pdf and jpeg format scanning problem in Canon iR2018 copier
Yes,you do have to buy the sent kit.But remember the sent kit Scan to e-mail and not directly to the computer.Your company have to have a mail server to be able to work properly.Adobe have software that you can buy that chance word document to PDF.
Feb 11, 2009 | Canon iR 2016i Black and White Copier
HP Deskjet F4280 All in one will not scan
Open Paint, from Start>All Programs>Accessories and select File>From Scanner or Camera...
Dec 11, 2008 | HP DeskJet F4280 All In One Printer InkJet
EPSON Scanner 4490 Problem
So you've completely ininstalled. Now you should download and install nCleaner, and do a Clean System, and then a Clean Registry. Now:
Download and install the latest 4490 driver software from here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=+ab4PwTTw7cRmkks+y0Lel8FKCE2A3PV7yPoa5gsU002FboU003D
The Epson Copy Factory Update may be of some use to you also.
Hope this helps
Chris (ziraffa)
Dec 08, 2008 | Epson Perfection 4490 Office Flatbed...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
67 people viewed this question
Seeker5211
Seeker5211
