Question about HP PhotoSmart C4280 Laser Printer
Printer works scanner will not connect
Older preinter/scanner newer computer with vista
    Problem Solver:
  • 10 Answers
Check for driver updates.
Posted on Sep 12, 2009
Hi there - I have an older Mustek Plug-n-scan (includes Corel draw) Select Edition 600CP, probably purchased around 2000 but had only 18 months use - has been in storage since - what sort of price could I...
Most computer accessories, printers and scanners today use USB connectors between the unit and the computer. The older scanners do not have USB capability and will not be compatible with the newer computers. Only with add-on cards and cables can they be made to work.
As for selling it you would do better to donate it to Goodwill etc and get the tax donation slip for it.
If your scanner does have the newer USB connector, you will only have a $10 +/- scanner. The software, Corel Draw is outdated and not compatible with the new operating systems. There may be an update available from Corel which may require a prior product registration to qualify for. However most software packages included with printer and scanners etc are "SE" special editions, which are very basic trial versions and not the full featured retail versions.
Apr 13, 2011 | Mustek Plug-n-Scan 600 Flatbed Scanner
I want flatbed13 scanne drive fo vista o win 7
Many (most) older scanners will not work with newer hardware and OS. Go to the website of the scanner maker and see if they have drivers for your OS. If yes, get it and continue, if no, get new unit. If you have to replace, look for a network based printer, no host required, except for set up...
Feb 23, 2011 | Computers & Internet
Can I get a driver for the epson perfection 1200 scanner that is compatible with windows vista. at present it will not work with vista and I am told no driver is available, otherwise I have to buy new...
this is pretty ancient model, but... you can try to use winxp twain driver and it should work, your registry most probably will need bit of tweaking... version which will most probably work is TWAIN Driver v5.53A,
follow this procedure, disconnect your scanner from computer, run ccleaner to clean all rubbish, including registry clean.
download twain driver and then run it, force vista to accept it, reboot your computer. connect scanner and you will have then warning from vista about digital signature, disregard it and force install software. scanner should work.
i still would suggest newer version...
Jul 20, 2010 | Epson Perfection 1200 Photo Flatbed...
My computer is toshiba vista have tried to connect my older scanner but message comming back reads - cannot communicate with scanner if using scsi connection restart computer. Also say's fine scan cannot...
its possible that the driver for your older scanner is not compatible with vista this is often the case. the disc that came with your scanner will tell you this ie: for use with win 98, me, xp. if it doesnt say vista you will have to search internet for a vista driver or go to scanner make(ie: epson.logitek) internet site and see if there is a drver there. hope this helps
Jul 08, 2010 | Computers & Internet
Printer is not working with my new a6742p pc
Yes. It should work fine, but there are a few IFs:
IF the printer is still good...you said it's an older printer. Also, does the printer have a USB port, or is it so old, it only has a parallel port? Some newer computers do not have serial or parallel ports.
IF you don't have a parallel port on the PC, and you have no USB port on the printer, you can purchase a parallel to USB adapter.
You also may have to go the manufacturer's web site to download the drivers for the printer.
IF there are no printer drivers for your newer Operating System, you are up the proverbial ******* creek. I have a hunch you are concerned about how to hook it up because of the above mentioned parallel - USB port issue. The adapter will fix that.
Good Luck!
Apr 07, 2009 | HP PSC 1350v All-In-One InkJet Printer
Connecting an older Minolta Dimage Elite film scanner to a newer computer running Windows Vista
Paul you might want to see if VueScan http://www.hamrick.com/ supports this particular scanner. It often allows older scanners to work on newer computers as it bypasses the Twain drivers.
Jun 20, 2008 | Minolta Dimage Scan Dual II Film Scanner
Failure to connect printer to laptop
what's your printer model? Have you've checked the compatibility settings? Because not all models of printers and as well with software and hardware programs are compatible with a certain unit especially if its newer model/ version. If you're laptop is bit older of its age. You need to update and upgrade some of your'e devices and update them to make it will function well.if your'e installation CD is for Windows XP SP2 and Vista and your'e laptop is an running an older version of windows. it won't really install at all.ok?
Jan 15, 2008 | Office Equipment & Supplies
Windows vista drivers
Sadly if printer manufacturer doesnt support Vista then you are out of luck. Sometimes if a printer has a big userbase, for example design studios or printing firms. Then a 3rd party might produce unofficial drivers. I have had a look but cannot see anywhere that are offering Vista drivers.
Aug 23, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Connecting the scanner to a new computer with Windows Vista
If the Acer has an parallel connection and not USB this indicated to me it is an older machine from the Win98 era. In which case it will not work with Vista. Indeed many newer devices do not work with Vista there is a real issue here Check back with Dell on this.
Jun 09, 2007 | AcerScan 620P Flatbed Scanner
HP PhotoSmart C4280 Laser Printer Logo
Seeker5211
Seeker5211
