Question about Toro Lawn Mower With Toro Power Tools
Drive belt slipping, not propelling mower - Toro Lawn Mower With Toro Power Tools
    Habit-Forming:
  • 139 Answers
Adjust belt tension or replace belt with new or slightly shorter one
Phillip
Posted on Sep 12, 2009
SELF PROPEL NOT WORKING
usually john the belt will stretch and start slipping. if you take off the cover and see if the belt is still on the pulleys turn it a few times to see if it is tight if not replace the belt.
Apr 29, 2016 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Self propelled not working
The weakest link in your problem is the belt, and it's path. The belt comes off the engine crankshaft and goes to the self propel shaft at front or back of your mower. I believe your problem is that your belt has broken, or just slipped off of a pulley. Check the drive belt and you should be OK. GOOD LUCK FRIEND.
Sep 15, 2014 | Garden
The self-propelled mechanism on my EZ Walk Craftsman does not work. Anyone have a solution?
What you can try is to open the case surrounding the self-propelled drive and make sure that the belt has not either slipped off or has broken. Depending on the model, the case has two or four screws securing it to the frame of the mower. If the belt has slipped off, you can unscrew the tension screw and slip the belt back on and then tighten the tension screw so that there is enough tension on the belt to keep it from slipping off.
If the belt has become broken, you can purchase a new one from Lowes or Home Depot for approximately 15.00. The change out procedure is pretty straight forward and shouldn't take longer than 5-10 minutes.
If the belt is fine (not loose or broken) it could be a gear problem in the drive wheel, in that case you are in a little bit more trouble than simply replacing the belt.
Hope this information helps.
Thanks,
May 09, 2011 | Garden
Belt jump off the drive pulley
I don't have this kind of mower. But I was faced with the same problem recently. I got my belt back on by taking a large wrench and affixing it to the bolt head holding the pulley which you want to slip the belt on. Hold the belt firmly against the pulley and turn the wrench and the belt in the grove will walk around the pulley until it slips in place.
Apr 02, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Drive wheels dont seem to propel mower
SOME SELF PROPELLED MOWERS HAVE A SHEAR PIN IN THE DRIVE BOX THAT MAY HAVE SHEARED . IF THE MOWER GETS A LOT OF USE THIS PIN CAN SHEAR. ALSO SOME HAVE A FRICTION DISC, LIKE A CLUTCH THAT MAY BE SLIPPING. CHECK THESE TWO THINGS CAN'T TELL MUCH MORE WITHOUT A MAKE AND MODEL
Sep 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Mower Belt Slippage
If you have an tension adjuster on the handle loosen up until you can slip it back on. If thats not enough remove the spring at the tranmission.
Jun 10, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My self propelled mower doesn't fully engauge
What usually causes this is called belt stretch, this happens due the weather and the heat from the engine
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Self propelled motor mower runs but doesn't drive
problem could be:-
1 broken drive belt or it is slipping ,if so simply tighten drive cable
2 drive pulleys worn allowing belt to slip
3 teeth in drive wheels damagedcheck these out first
Mar 15, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
545 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
