Question about Acer Aspire 3680 Laptop
Screen doesn't display - Acer Aspire 3680 Laptop
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 168 Answers
Try this. if your laptop supports dual monitors this may work for you. Take a regular crt monitor and plug it into the side of your laptop. Then start your laptop. if I do mine this way when it starts it will automatically switch the display to the new monitor. if this does not work then a pin from your display may have come disconnected.
Posted on Sep 12, 2009
Lg tv cf20s12e
CHECK TV OSD(ON SCREEN DISPLAY ) SETTING
Jul 19, 2013 | Televison & Video
My apple compouter screen doesn't display properly
Hey all you have do do is go on system preferences go on display and you should have size options chose a size option apply then restart easy
Jul 07, 2013 | Cell Phones
My display screen doesn't work and the camera turns on but would not turn off
Hello, Sounds like internal malfunction, needs to be checked by service tech.
Dec 16, 2012 | Kodak EASYSHARE M1063 Digital Camera
Screen broken-scissors thrown at screen-tv works but screen doesn't
Display might need replacement. It is better to show it to a qualified service technician.
Jul 17, 2012 | Vizio L37 Television
My canon ir3100cn displays "finisher
My canon ir3100cn displays "finisher can not be used" with on screen. i'm using saddle Q2 finisher. it doesn't move at all.
Sep 03, 2011 | Office Equipment & Supplies
Toshiba NB200-11M, display not working. Replaced screen and lead but no different. External monitor displays fine.
Is the display slightly visible? As in seeing shadows on the screen? You may need to replace the inverter board.
If you have replaced the LCM cable (the cable that connects the screen to the motherboard) and the screen and replacing the inverter board doesn't work then you have motherboard fault.
Jul 23, 2011 | Computers & Internet
Colored bars across laptop screen
You should try to connect your laptop to external display and use the same resolution as on your laptop internal screen. If the picture is good, there are 2 possible solutions:
1. The wire connecting the screen and your laptops motherboard could be lose. Use screwdriver to disassemble the laptop so you can see both ends of that connector and make sure that they are on place. In some laptops it is enough just to take off the keyboard and you can see the other end of the cable. Try to push that one to place before dissassembling more.
2. If that doesn't help, I would try to change the entire screen. While doing this you should remember that you laptop doesn't necessarily need the original spare part, you might find one for free from one of your friends old broken laptops, as I did, it doesn't even have to be same make and model. (Mine was packard-bell laptop, and I took the replacement screen from my friends old HP, the most important thing is that it is the exact same size).
If the picture is the same when connected to external display (this is wery unlikely in this case), your display card is broken, in some laptops you can replace it, but in most cases you cant. To help you furter, I would need to know your laptops make and model.
May 02, 2011 | IBM Computers & Internet
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 3680 Laptop Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
