Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
How to use the after filters for the electrolux canister vacuum
  • 430 Answers
At the back of the vac on top you will have a removable grille. Release the thumb tab to lift the grill.Older models had this tab at the back of the grille. The filters will sit underneath. They should clip into the round exhaust opening. Then replace the grille. Change filters every 6 bags. More often if you have pets or allergies.
Posted on Sep 12, 2009
How do I change the air filter
the top of the vacuum where the tools go comes off,the filter goes underneath..Chris
Jun 25, 2014 | Electrolux Guardian Bagged Canister Vacuum
Where is the filter on an electrolux canister and how to you change it.
This model has the filter beneath the tools/attachments.
Open the hatch to gain access to the tools. Release latch/tab at the front of the tool holder, and lift. Remove and replace filter. This should be done every 6 bags.
For additional information, check your manual, or download one from the below link. The Guardian will be listed under "older models".
Dec 12, 2010 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Oxygen Canister doesn't work.
something is blocked/clogged up check the filters.adrian,,,,
Jul 07, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Trying to find filters for the vacuum
If you use Electrolux bags, they have a built in filter. I don't know of any aftermarket filters.
Dec 28, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Mar 01, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vacuum
Mmm cant find any info on this machine. Did you buy it in CAnada?
However. If you can find where the exhaust filter is, the bit where the air blows out, take off the cover and filter. If there is an exhuast blower it will be here.
I have to say that of late Electrolux have done away with this on most machines
Rob
Feb 19, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Bags
go to website for Aerus, which is the new name for older (grey) Electrolux vacuums. Long story.
website
http://www.aerusonline.com/
follow link to find dealer or order online.
J
Jun 11, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Advantage Series canister vacuum
There is an area on the back of the tank where you will see lines, put your thumb there and pull the top half of the tank towards yourself. That should open the machine so you can replace your after filter.
Nov 18, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
