Question about Toshiba Satellite 15" Flat Panel LCD Monitor
Toshiba Satellite laptop continually shuts down. Have tried running with battery, on AC power only (no battery installed) and it continues to shut down. Help?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 168 Answers
Unfortunately is sounds like your system has been compromised by a virus; which has erased or corrupted needed system files. before you give up and reformat your system you should try the Spinrite program, written by gibson research co. you can DL it here .. http://btjunkie.org/torrent/SpinRite-6-0-Release-1/3779c30edea9218ee5596b3b8c62a0aecc56767e1047
you will need a torrent service like; utorrent, shareaza, etc
Posted on Sep 12, 2009
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
TOSHIBA U400 running VISTA; When I am on battery and get low i plug in so i can continue working but even though the lighted icons on the laptop show it is plugged in and charging and the toolbar icons...
Yes it is, seems there is some problem with the power state detection and changing of the load mode. Might by a physical problem, so I am not sure you can fix it.
At least check your power plan details and see if there is any error with the ACPI devices in the device manager.
In general, if you use the laptop when plugged, you should take out the battery to maximize the battery life (prevents useless load cycles).
Also configure Windows to optimize battery usage.
Apr 24, 2010 | Toshiba Satellite Pro U400-S1001V Notebook
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Jul 30, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba satellite lap shut down. charged and now will not turn on
Try on AC if works replace battery!!swampratt200!!AAAEEE!!!!
Jul 21, 2009 | Toshiba Satellite A60-S1561 Notebook
Toshiba's A135-S4527 Battery isn't working anymore
Have the battery checked or better yet, replaced. Prolonged use might damage the charging circuitry of your machine.
Jan 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Laptop won't run on ac power and keeps shutting down
Check that the AC power works, go to a repair shop and test a different one or have voltages checked with a multimeter.
If the AC adapter is fine, then it is usuall because AC socket solder joints on laptop are broken. In this case , it is a delicate repair, and must be done by an expert repairman.
Dec 13, 2008 | Toshiba (K000006610) for Satellite P25...
Toshiba Satellite A35-S159 Shut down
If it does the same thing when it's plugged in, it might be time for a trip to the service center.
Mar 21, 2008 | Toshiba Satellite A35-S159 Notebook
Laptop does not power on
Somtime low cmos battery could cause the pc not to start.
Take battery out /plug in your ac adapter
Shut down computer
hit f2, this will reset the bios.
Good Luck, Merry Christmas.
Dec 05, 2007 | Toshiba Satellite A135-S2246 Notebook
Toshiba Satellite 15" Flat Panel LCD Monitor Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
