Question about Kenmore 24032\24036 Top Load Washer
Washer fills up but the will not wash
Once the water fills up the agitator looks like it is going to spin and moves a tiny bit then stops and just hums. If I open the lid it will stop if I move it to the spin cycle and when I close it again it hums again so I dont think it is the lid switch.
  • clubs241 Sep 17, 2009
    It appears the pump is unclogged any other suggestions?
  • 110 Answers
Sounds like something is clogged in your pump under the washer.
see the motor drives the pump, but if it is clogged, the motor will not turn.
Posted on Sep 13, 2009
Fills with water but then does not agitate. Agitator moves only tiny bit in both directions. Pumps out and spins OK but makes grinding sound when finished spinning
I do not work on washing machines, But I had the same problem with my own unit. Replacing the transmission fixed it. I hope this helps you.
Mar 07, 2015 | Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Will agitate but won't spin leaving the water in the tub.
the transmission may have been damaged during the runaway.to much movement can cause it harm that is why they come with a shipping rod in them.
Aug 08, 2009 | Kenmore 22422 Top Load Washer
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
178 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
