Question about HP Photosmart C4180 All-In-One InkJet Printer
Scans, copies fine but will not print photos from
Scans, copies, fine but will not print photos from Photoshop Elements 6 or i-Photo
Silan
  • 54 Answers
SOURCE: Prints black page
Click Start - All programs - HP - HP Director/Solution center
Click Settings - Print settings - Printer settings
Click on the Colors. In Color Management select "Managed by Application". Click Apply and OK. Close HP Director/Solution center.
Try printing.
Posted on Jan 09, 2008
SOURCE: hp F4180 No copy to Plain paper
If you just replaced the ink cartridges, make sure you've removed the plastic tabs that cover where the ink shoots out. If they are old cartridges, make sure that the nozles haven't dried up. Remove the cartridges and dab a cloth (one you don't mind staining) where the ink shoots out, if all the colours show up, it's clear. If you notice very little colour, or none at all, try dampening the cloth and wiping down the cartridges to promote inkflow through the nozles. Hope this helps.
Posted on Jun 02, 2009
ajuhere81
  • 256 Answers
SOURCE: HP 1401 Prints, not scans
use the following link to download the latest updated drives and software from the link below. you can also get the solution
Posted on Aug 20, 2009
  • 76 Answers
SOURCE: My Printer won't print. It scans and it copies. There are No ligh
1) If it worked before, you can do a system restore to the last time you remember it working which should clear the problem. Also, 2) Check your printer folder (in "Control Panel") and see if it is listed as a "printer" in there. You may need to reinstall the drivers if you don't see it, Sometimes the driver disk has a repair install option.
3) It may not be "check marked" as your default printer device (in printer folder) which you can easily change by right click on its icon and choose "set as default".
Posted on Sep 15, 2009
  • 54 Answers
SOURCE: My HP Photosmart D7360 only prints part of the
is it printing fine from other application if yes,
then just to inform you that there is a problem in printing from HP printer with OLD ADOBE VERSIONS which has been fixed in the new versions of ADOBE
Posted on Oct 15, 2009
Scanned document is 8.5 x 14 even though setting says 8.5 x 11
You probably have the PDF programme page size settings incorrectly set to the larger size = why only able to print some of the length. As a solution, use a photo programme (Photoshop, Elements or the excellent FREE Faststone Image Viewer to resize the image so it will then print on your paper but so doing will reduce, slightly, the width to suit the revised shorter length to preserve the proportions/balance between length and width.
Apr 01, 2014 | Epson WorkForce WF-2530
My pictures are in the camara memory not on the sd card I did down load the pictures to my computer but whow do i transfer to a sd to be able to printe also do I need to buy adobe photoshop?
In the camera menu is an entry for "copy". This gives you the option to copy the internal memory to a memory card. You do not need to buy Photoshop unless you are an advanced photographer who spends 6 or 7 hours a day editing photos. Besides, it costs over $800. You could try Photoshop Elements...it's only $99. Or, you could try some less expensive or even free photo editing software. It all depends on how serious you want to get into photo editing.
Nov 30, 2010 | Canon Cameras
Photoshop elements 6 will not paste photos
Check your firewall settings, that is what blocking your copy accessing restriction.
Dec 17, 2009 | Adobe Photoshop Elements 6: Windows
Won't print! it scans photos but it won't print
as it is not printing u can try making copies . if it copies fine that means the issue is with software but if it is not copying properly that means the problem is with hardware. u can try with uninstalling the software and reinstalling it .
Oct 06, 2009 | HP Photosmart C6280 Printer
I have the following message and I understand the problem may be with Adobe Photoshop Elements 6 The appplication has failed to start because connAPI.DLL was not found. Re-install may fix the problem
Hi there.
Do one of the following solutions: Solution 1: Remove the NOKIAManager.mox file.
  1. Exit Photoshop Elements.
  2. Open the C:\Program Files\Adobe\Photoshop Elements 6.0\moxplugins folder.
  3. Move the NOKIAManager.mox file to the Recycle Bin, or another location such as your desktop.
  4. Restart your computer.
Note: The NOKIAManager.mox plug-in file is required for Adobe Photo Downloader to download photos from a Nokia mobile phone. If you use a Nokia mobile phone, use Solution 2. If you later decide to use a Nokia mobile phone, either move the NOKIAManager.mox file back to the original location or reinstall Photoshop Elements.
Solution 2: Install or reinstall the Nokia PC Suite software.
Note: Only use this solution if you connect a Nokia mobile phone to your computer.
In order to communicate with a Nokia mobile phone, your computer must have the Nokia PC Suite software installed. Install the software to allow Adobe Photo Downloader to communicate with the phone and download photos from it. If you have previously installed Nokia PC Suite but are still getting this error message, uninstall and reinstall the software or upgrade to a newer version. For more information about Nokia PC Suite, contact Nokia or visit the Nokia web site.
Solution 3: Disable Adobe Photo Downloader.
  1. Open the Organizer in Photoshop Elements.
  2. Choose Edit > Preferences > Camera or Card Reader.
  3. Disable the Auto Launch Adobe Photo Downloader On Device Connect option.
  4. Click OK.
Note: This solution will prevent Adobe Photo Downloader from starting when Windows starts, and it will not appear automatically when you plug in a camera, card reader, flash memory drive, or other memory device. When you plug in one of these devices, and in order to download photos into the Organizer, you will need to start Photoshop Elements and choose File > Get Photos or Videos > From Camera or Card Reader.
Good luck and thanks for using FixYa!!
May 01, 2009 | Adobe Photoshop Elements 6: Windows
Problem loading Photoshop Elements 6 to Mac from CD-Rom?
You probably received a faulty disk, just return it to Amazon and ask for a a replacement.
Regards -- Joe
Feb 06, 2009 | Adobe Photoshop Elements 6 for Macintosh...
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Insignia digital photo frame won't recognize some .jpgs
When you save in Photoshop make sure you select "Baseline ("Standard") on the JPEG options when you save. That should fix the problem for you. It did the trick for My Kodak SV710 digital frame which wasn't displaying images I had edited in photoshop.
Dec 11, 2007 | Cameras
Photo formats
iPod Main | iPod Q & A (Main) | Next Q & A Section Q & A: iPod Q & A: Transfer & Connectivity (6/6) What graphics formats does the iPod photo/"Color" recognize? iPod nano? According to Apple Support Document #300241, on the Mac, iTunes 4.7 (and higher) can recognize and prepare "JPG, TIFF, PICT, GIF, PNG, JPG2000 or JP2, PSD, SGI, and BMP" images for display on the iPod photo/"Color" and iPod nano. On Windows, iTunes 4.7 (and higher) can recognize and prepare "JPG , JPEG, BMP, GIF, TIF, TIFF, and PNG" images from "Adobe Photoshop Album and Adobe Photoshop Elements" for display on the iPod photo/"Color" and iPod nano. However, in disk mode, you can copy any type of file to the iPod for transport to another computer.
Sep 29, 2005 | Apple iPod nano
HP Photosmart C4180 All-In-One InkJet Printer Logo
19 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
