Question about Hanns.G Corporation JW-199DPB 19" LCD Monitor
Blue amber flashing no picture
Two monitors any luck
is ther a reset
  • mail84 Sep 12, 2009
    capacitors are all ok, monitor less then 18 month old
    cant access menu nothin on display
  • 1,684 Answers
Very common problem with these monitors after 2-3 years. The power supplies have died. Go to our web site and we have repair guides for Hanns-G monitors. The problem is the heat buildup in the case has caused the capacitors in the power supply to blow. If you can solder you can fix your monitors. Go to our web site at: www.ccl-la.com/badcaps.htm check out the pictures of what to look for in your monitor. Open the back and replace any that look like the pictures. Be sure to use high temp caps (105c) not like you would find at Radio Shack or you will have to do it again in a month or two. We carry the caps in stock or they can be ordered from several places. Just install the new caps with the polarity strip going the same way as the old one came out and solder them in. You should be back going in no time. If you don't want to do the repair yourself we do offer a repair service for $35 + return shipping. Let me know if you have any questions.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 12, 2009
  • 125 Answers
It sounds like the monitor is not detecting the computer. All of those flat-screens tend to have a reset setting in the menu. Press the menu button on the monitor and scroll down to the section for resetting to factory default.
My ViewSonic NX1932W LCD Monitor was being used as a computer monitor. It stopped working with the power button displaying the amber color. If I hold the power button it will flash blue and return to...
these monitors are tightly held in place by clips. After removing all the necessary screws, use somehing like a credit card to pry open the lid. Just need to be careful not to crack the case, or your hand.
Oct 12, 2013 | ViewSonic NX1932W LCD Monitor
Acer V173 with flashing amber led. No picture. cable good. other monitors work at this connection.
I have this same problem. Blinking amber Light and no display. on close examination I am seeing the video image attempt to come up, but with no back lighting. I think there is a power supply problem. I will post again if I learn more.
Feb 24, 2011 | Acer V173 b Monitor
Nothing comes up on the screen
The monitor connected to the system is set to receive video signals from the DVI port on the video card and it is not getting a signal.
Possible Causes:
  1. Monitor is connected via VGA (Blue Connector). Fix by using the input select button to select DVI input)
  2. The video cable is not connected to the correct port on the system (Or not connected at all)
  3. The monitor is on, but the tower is not powering on or failing to complete the Power On Self-Test (POST). It the power LED on the tower is NOT on, or solid or flashing Amber then the tower is not posting. Flashing amber is normally a bad power supply, solid amber is the motherboard.
Mar 01, 2009 | Dell OptiPlex GX280 PC Desktop
Proview 22
try test the LCD to other PC, if it is working on other PCs, then your VGA card might be the cause. And if the same problem happens to other PC's then the LCD is at fault. Remember to Check the VGA cord. Good luck.
Nov 27, 2008 | Computers & Internet
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Netgear Test Mode (remains amber)
hi sounds like thers not enough volt either on the DC input because of the y spliter - take an adapter for each one check again if there is a good line good luck
May 04, 2006 | NetGear FVS318 Cable/DSL ProSafe VPN...
Hanns.G Corporation JW-199DPB 19" LCD Monitor Logo
624 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
