Question about Kenmore Sewing Machines
I took off the tension adjuster dial on my Kenmore Modifier model 158.16250 and can't seem to reassemble it properly
Mimito7
  • 128 Answers
SOURCE: Top tension adjustment
Believe it or not, most computerized machines have an automatic tension. This works well providing, the thread is thru the tension wheel setup.
But for further reference,
loops on the bottom-- problem on the top.
loops on the top--problem on the bottom.
Mimi
Posted on Apr 24, 2009
redbeard00
  • 957 Answers
SOURCE: Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Posted on Apr 26, 2009
  • 51 Answers
SOURCE: tension dial not correcting tension problems
Look to see if the 'check spring" is still there, and not broken.
If the tesion nob can be truned without any feeling of tension, then maybe the screw that attaches the 'tension housing' to the stem has loosen or broken.
Posted on May 10, 2009
  • 111 Answers
SOURCE: Need instructions on how to
If you go to www.searspartsdirect.com you can type in the model of you sewing machine and it will pull up a parts breakdown of your machine. Just look for the section that contains the tension unit. You might be able to reassemble the tension unit once you see all the parts in an exploded view.
Posted on Apr 29, 2011
SOURCE: bobbin tension problem with kenmore model 385.16231300
I discovered the same problem. What I figured out (after having the machine "repaired" several times) is that it seems as if the bobbin type may be the suspect. I started looking closely and it seems as if I have 2 different types of bobbins. So, I tried both types. Since I don't know the bobbin number(s), you will have to put up with my description .... the bobbin that is flat, top & bottom, seems to bunch up. The bobbin "bounces" when I sew. The bobbins that are rounded on the top and bottom don't seem to "bounce" and it doesn't bunch up the lower thread. Now, I have read my manual front to back and it does not say what bobbin type or number to use. So, if anyone knows, it would be a great help. I am assuming the correct bobbin is the "class 66" bobbin. Does anyone know for sure?
HAVE KENMORE MODIFIER- THAT IS ALL IT HAS ON IT -- NO NUMBER - i NEED TO KNOW HOW TO SET THE STICTHES . AND BASIC STUFF
Have never heard of a Kenmore "Modifier," but if you search the internet, you may find information:
Sew with Kenmore Modifier
Kenmore Sewing Machine Instruction Manuals and Repair Manuals
Kenmore 1357 Instructions Manual
Even if you are unable to find a manual that matches your machine, frequently the models are very similar and may be enough to be helpful.
Apr 27, 2016 | Kenmore Sewing Machines
How do I rebuild the upper tension mechanism for a singer sewing machine model 507?
It's far too complicated to explain on here. You need to get a service manual for your model, or find one with a similar dial. Make sure the manual covers tension dials. Getting the spring wound correctly can be a challenge. Have you checked to see the if the presser foot lever is pressing against the tension dial from the inside of the machine?
Mar 01, 2015 | Singer Sewing Machines
I have a Kenmore sewing machine - 12 stitch model which I bought in the 70's. I am having a tension problem and can't seem to fix it. What is the normal setting for the top, and bottom?
Hello
Load your Kenmore sewing machine with the right thread and bobbin thread for your project. If you use the wrong weight thread for your fabric or severely uneven weights of thread, this can cause the appearance of a tension problem when it is, in fact, a thread weight problem or a problem with your sewing speed. If you go too fast, you will break the thread. If you go too slow, you can cause loops. Uneven pressure can cause stitches to vary greatly.
Test your Kenmore sewing machine's tension by sewing on a piece of scrap fabric. If your tension is way off, then test on some basic cotton or a firm blend simply to get your tension right. Do not try to start adjusting your tension on silk or leather. Get a base adjustment on a more standard fabric first.
Look at the top threads and bottoms threads. If the tension is off on one side, it will usually affect the other side slightly. So select the side that looks more maladjusted to start adjusting the tension.
If the top thread is too loose or too tight, you will need to adjust the tension dial. This dial is usually located a few inches above the needle on the Kenmore machine body. Usually, your machine will have markings to indicate which direction tightens the tension. If these have worn off over the years, watch the dial as you turn it. If it appears to move toward the machine body, then it is tightening.
If the bottom thread is too loose or too tight, then you will need to open the door to the bobbin case. On some Kenmore models, there is a little screw near the bobbin case that can be adjusted slightly to adjust the tension. On other Kenmore models, there is a screw on the bobbin case itself--not on the bobbin, but on the bobbin's casing. This will also adjust the bottom thread tension. Adjust the bobbin thread tension to make slight changes.
If the thread is looping severely on one side, the thread weights might be off. For instance, look to see if you have a lightweight thread on the bobbin and a heavyweight one on the top. If the thread keeps breaking, the top tension or bottom tension could be too tight or the thread is too lightweight for the material you have selected. Check your combination of threads and material. Also make sure you are using the right weight needle and the right foot for the sewing step or project you are working on.
If your Kenmore sewing machine's tension is off severely or if you have not used your Kenmore in a long time, then you might need to take your machine in to be serviced. Sometimes, the inner parts need to be oiled or the entire machine might need to be cleaned and calibrated by a professional. If you sew a great deal or if your machine sits idle a lot, both situations will usually require some servicing to keep your Kenmore sewing machine and its tension in perfect working condition.
Jul 11, 2011 | Kenmore 15358
Need instructions on how to reassemble my tension adjuster on Kenmore model 385.1551. Please help.
Apr 26, 2011 | Kenmore Sewing Machines
Inherited old kenmore 10 sewing machine. it is clean and have no problem threading etc. but believe tension and settings are off because back of stiching is pulled and "loopy" what are the correct...
It sounds like your upper tension is too loose. A good place to start adjusting is at the number three on your tension dial, but you need to pay attention to how the stitches look rather than what the number on the dial is. I wrote a Tip on Adjusting Tension. Take a look at that and see if it helps.
Robbie
Aug 01, 2010 | Kenmore 744-08BH Mechanical Sewing Machine
Is it possible to download a manual for the kenmore 385 12912 I cannot adjust the tension properly and am not certain whether I am possibly threading the machine wrong or fitting the bobbin in wrong Help
tension can be tricky because it must be adjusted to each different types of fabric and proper needle size to each fabric try google sewing machines then enter the model number and then enter HOW TO THREAD
Dec 12, 2009 | Kenmore Sewing Machines
Kenmore Sewing Machine Drop-in Bobbin Tension Adjusting Problems
looped stitches are usually caused by improper tension. when the loop is on the upper side, it may be corrected by loosening the top tension or by tightening the lower tension (turn the tension screws on the bobbin a hair at a time)
since using the machine only a few times it is best to clean the machine from dust (can use a can of air) blow air into the bobbin area and between the tension disks and under the throat plate.
make sure the machine is threaded correctly and bobbin is evenly threaded
Aug 26, 2009 | Kenmore Sewing Machines
Bobbin tension problem with kenmore model 385.16231300
If You have a drop in bobbin you will have to remove the hook and adjust the tension, however try adjusting the top tension before you remove the hook.
Jul 17, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Euro-pro 464xc bottom tension loose
Welcome to FixYa!
Loose bottom stitches come from the top, not the bottom. Seems weird, but that's the way sewing machines work.
The dial tension should be set at the mid range and make absolutely sure that you have the machine threaded correctly. Both things will cause a sloppy bottom stitch.
Thanks!
If you find my solution helpful, I'd appreciate a FixYa rating....
Jan 15, 2009 | Kenmore 12102
Bobbin on 12102 kenmore
Welcome to FixYa!
Don't mess with the bobbin! They rarely need adjustment. Sloppy bottom stitches usually come from two things. Tension too loose on the tension dial or improper threading.
Dial tension should be set on about the mid range and you must, must, must, make sure that you have the machine in the proper thread patch. Have someone check it with you. Sometimes a fresh set of eyes will help you spot an area that you missed.
Thanks and if you found my solution helpful, please reward me with a FixYa rating.
Sep 26, 2008 | Kenmore 12102
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
