Question about Ovens
My wolf dual range oven does not cook anything thoroughly. do these ovens need to be calibrated? service rep said nothing is wrong..tried again today; have had chuck roast in oven for 5 1/2 hours @ 250 degrees and it is still not cooked!
  • rosesofcliff Sep 12, 2009
    we have done this and temp is pretty accurate but the food is still not cooking thru!
  • 3,741 Answers
In the oven there is a temperature sensor also called heating element.as when you adjust the temperature it shows that temperature on the display but the element /the temperature sensor is weak.so its not getting that heat.this part has to be checked with a meter to confirm the fault.this will help. --------------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 14, 2009
    Brigadier General:
  • 4,044 Answers
Ok, get an a thermometer that you set on the grills inside the oven and check you temperature by this instead of the knob. I don't know of any calibration that is required but it is possible the markings are incorrect. If the temperature is correct the oven is working correctly.
Posted on Sep 12, 2009
    President:
  • 1,714 Answers
The easiest and quick fix is to put an 'oven thermometer' in qa verify the 'actual' oven temp and then make the necessary adjustment to get it where you want it. Then you're roast will be ready when you are! Happy cooking.
    Scholar:
  • 86 Answers
Hi there, It is simple to test this - buy a hi-quality oven thermometer - test it at 300 degrees in the center of the oven. Here are instructions for calibrating a Wolf oven: http://wolfstoves.com/Wolf/Commercial/WolfTempCalibration.pdf If it is off then following these directions will correct the setting.
Kenmore oven take a long time to heat up, but bakes just fine once it reaches temperature. Is there anything I can do to speed up the heating process?
Start earlier?
>> check all elements for current,
check seals
check temperature calibration (allowed to be 15% ie 180 can be 153 or 207 Celsius!) no wonder Margs' scones cook faster at her house :-)
Oct 15, 2013 | Kenmore Elite Stainless Steel 40" Dual...
I have a 30 inch wolf range I took the door off of. I'm trying to take the door apart but there are 2 screws behind the logo plate that need to come out. The problem I'm having is getting the logo plate...
A plastic putty knife can help, but the logo is held on with double sided tape and the Wolf parts book always says to order a new logo whenever you order anything that requires removing the logo
Aug 07, 2013 | Wolf Range WKGD-2 Gas Double Oven
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Samsung oven error codes
you need the service rep or repairman
Jan 12, 2012 | Ovens
Oven not cooking evenly
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 11, 2011 | Wolf Range Ovens
Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 26, 2009 | Wolf Range WKGD-2 Gas Double Oven
What does the error code F1 indicate, on a Wolf Oven?
Mar 24, 2009 | Ovens
How to clean gas wolf oven
No. Because if you dont get all the cleaner off you dont know if it would be toxic or not.
Jan 16, 2009 | Wolf Range WKGD-2 Gas Double Oven
Ovens Logo
74 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
