Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Belt not turning, it is not broken - Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
  • 34 Answers
The shaft that makes the belt spin is most likely not spinning. Take it into a vacuum shop
Posted on Sep 13, 2009
Auger beater bar won't turn.
did you check the belt?
Nov 27, 2015 | Vacuums
Kirby brush bar is not turning?
Turn off your vacuum and unplug. Look at the brushroll and belt, check if the belt is broken, stuck or stretched out. If the belt is fine, check the brushroll, is it worn out (barely any bristles left) and are the ends warped or melted. Also make sure there is no fibers or hairs wrapped around the brushroll, especially the ends.
GoodVac.com
www.goodvac.com
1-800-775-6586
Aug 26, 2014 | Kirby Vacuums
The turbobrush for my cleanview helix 22c1 is not working
It's probably either just dirty, or the belt is broken. If it's dirty, you can just take the cover off (two Phillips head screws on the bottom) and clean everything off the brush.
If the belt is broken, you can tell by turning the large gear at the back of the brush -- if the brush turns when you spin the gear, the belt isn't broken -- then you'll need to replace it. You can buy a new belt online, or you can buy a replacement Turbo Brush directly from Bissell ($24.99).
Hope that helps!
Jan 10, 2011 | Bissell CleanView Helix 22C1 Bagged...
There is a loud noise coming from the bottom of the vacuum only when I have it on the carpet setting. It doesn't have this problem on the floor setting. What could possibly be wrong and is it easily...
Check for a broken belt or something caught around the brush. To check if the belt is broken, try turning the brush by hand. If it turns freely, then the belt is broken and needs replaced. It also may be loose. If that's the case, it won't turn easily, but still needs to be replaced.
Oct 03, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Motor turns on, but brush won't turn. belt is not broken
Sometimes hair and debris get in the end of the rollers and keep them from turning. Also, the bearings can become corroded and stick. Try removing the rollers and check for any debris and remove it. If the bearings are stuck, you can spray some lubricant or WD40 or them and try to free them up. On occasion the belt can come off of the motor. You can turn the unit over and see if the belt is moving over the roller. Good luck and let us know how you made out.
Mar 04, 2010 | Bissell 3920 Bagless Upright Vacuum
Brush not turning
The belt doesn't have to be broken to be non-functioning. If the belt is intact but stretched it won't turn the brush. You can get belts here:
Dyson DC14 Belts
Feb 14, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brush doesn't rotate on the turbo tool. the belt on it isn't broken it just seems really stiff to turn by hand as well
The belt doesn't have to be broken to be bad. Even if it is stretched or worn it will not turn the brush roll properly. Here is the belt you need and the manual which has instructions:
Dirt Devil Vision Turbo Belts
Download the Manual (PDF)
Dec 21, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Beater? bar doesn't spin
That means that the belt is broken, stretched or worn. You need to change the belt. You can get replacements here:
Replacement Vacuum Belts
Dec 08, 2009 | Vacuums
Brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Feb 25, 2009 | Bissell Upright Vacuum - The Pet Hair...
Kirby Vaccuum Cleaner:
likely a broken belt. turn vac over and see if roller turns free. if it does the belt is broken. turn the handle on front of vac. turn latch under headlight and remove head. open bottom plate and return handle to normal position. belt and brush roll will lift out. reverse procedure to install. directions are usually printed on the head of vac under headlight.
J
Jun 12, 2008 | Kirby Vacuums
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
97 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
