Question about Whirlpool LSN1000LW Top Load Washer
Washer and / or dryer causing stains
Our clothes are getting 2 types of stains. One is a blue stain. The stains are not streaking, I would describe them as blotchey. They are coming from the washer (about 6 year old Kenmore). We do not use fabric softner, only detergent.
The second is a brown (again blotchey stain) I am not sure if that is coming from our dryer (about a 15 year old Kenmore). Both problems are irregular and sometimes doesn't happen for a couple of months.
Not sure if it is time for new both or an easy fix?
Thanks!!!!
    Problem Solver:
  • 9 Answers
Bad news... chances are the seal is gone from the tub on the washer and grease from the transmission is getting into the tub. It's new enough you may want to go to the expense of the repair unless you are very handy and want to attempt it on your own. If my diagnoses is accurate there has been a trade of soapy water for grease and this means total tear down of the transmission to regrease. Hope I'm wrong or you are very handy. I replaced mine but it was older.
Posted on Jan 01, 2008
    Problem Solver:
  • 4 Answers
Better check the fabric softener dispenser because if at any time someone added undiluted softener it gum up and release at a later time especially on whites . The drum of dryer may have rust or paint missing inside or on the back , check this out . If drum is missing paint and wet clothing sets on that area long enough they will create rust .
My LG Front Load washing machine is leaving black streaks and smudges on my clothing. These streaks and smudges are ruining my clothes!
There can be several things that can cause this problem. The most common are:
1. Fabric softener - did you switch brands lately?
2. Chlorine bleach - if added at the wrong time
3. A mechanical problem with the washer, like a leaky transmission leaking oil.
4. Rust staining, sometimes caused by the water being used in the machine.
Here is a link to a site that discusses this issue more in depth:
http://www.stain-removal-101.com/washing-machine-stains.html
Jul 26, 2015 | LG Washing Machines
My Kenmore Elite Top-Load Series 700 Washer leaves streaks on clothing. It looks like dusty powder. I use liquid HE detergent. It was a normal cycle of dark clothes, not heavily soiled or dirty. Also
THE stains on your clothing especially on whites are most likely due to a top seal failure on your transmission. transmission leaking oil. if the clothing affected or the stain can be removed with a solvent like gas, kerosene, paint thinner repair on washer will exed the value .... if the streaks or stains can be removed with a water soluble detergent then the stains are caused by the soap and or hard water deposits in your washer . then the solution to cut way down on soap usage in your washer and or running an acid wash (soap is alkaline acid will dissolve it . make sure not to over solvent your clothes and to rinse all solvents out completely . be careful !!!! a solvent soaked t-shirt bunched up and left in tightly sealed plastic bag WILL CATCH ON FIRE!!!!
Jan 22, 2015 | Kenmore Washing Machines
Washer leaves oil type stain on clothes.what could be cause?
Stains on clothes from this model of washer are usually caused by the door boot or the tub bearing going out. I recommend cleaning off the surface of the door boot and if you still get stained clothes I recommend having the rear tub & basket checked. I am also sending you more troubleshooting tips in the image below.
Dec 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Duet Washer/Dryer get brown streaks on clothing
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What causes brownish stains and lines on white clothes
browninsh stains and lines geneally cpme from the dryer, not the washerif indeed it is the washer id look at between the front rubber boot for something stuck causing the marks
Mar 01, 2009 | Kenmore Washing Machines
Whirlpool duet front loader washer/dryer
It is not the dryer causing the problem. We get the brown streaks on our white clothes before putting them in the dryer. I have ruined more white clothes over the past six months with this Duet washing machine!!! We also don't use bleach so I don't think it is the HE/Clorox combo that somebody mentioned earlier. Anybody know what exactly is causing this yet... before I throught the moldy stain causing Whirlpool duet out?
Aug 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Blue stains on laundry
I was talking toa repairmain about which washer/dryer to get and he mentioned that the Bosch can stain clothing blue. I don't know anything else about why...but I'd contact my Bosch dealer.
Jul 06, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Stains from dryer
rear seal on drum needs replacing front 1 too if it has one the felt seals tend to turn brown and the "rust"will come back off on clothes leaving brown streaks
Jun 30, 2008 | Kenmore Dryers
Clothes dryer
It could be rust stains coming from the tub of the dryer during the drying cycle. The only concern is that rust stains are usually brown streaks on the clothes. I'd check the to make sure there are no rust stains on the tub, check the seal of the door to make sure its still in good condition. The last possibilty could be a good cleaning of the dryer (removing lint from the lint screen compartment and the tub of the dryer).
A schematic of your dryer can be found on www3.sears.com and should show how to get into your lint screen compartment and your tub.
Feb 07, 2008 | Zanussi TD4100W Electric Dryer
Whirlpool LSN1000LW Top Load Washer Logo
215 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
